... every single connect on cleaning with a wire brush in my adrenal tool and reassembly with Dielectric Grease everything started working again.
Yes that Adrenal Tool comes in handy especially if you discover Car is about to crush you while working underneath especially if you are doing something stupid.
All of those can be taken apart and cleaned up. And the quality of the replacements is not near that of the OEM Original Equipment part. But JP taking apart and cleaning takes a while to do. Getting that box from Moss and simple swapping switches is simpler. Take pics before you start disconnecting wiring,
JP the other reason foR that Voltage drop is that the ends of your wires have turned Green with oxidation. Time to take some sandpaper to all of the care wire terminations and clean off the green. Every wire connection needs to be taken apart and the green cleaned off. And then you will have 12 VDC once again. Surprised if car actually can start and drive running on 7-8 volts. Noodle on that thought awhile.
Right about no where to go anyway this year. Earlier in year I had heard that you could sit in quarantine at the Canadian border for 2 weeks and could then get into Canada. We were doing nothing but sitting in quarantine at home and I was really thinking about doing that. Maybe I had misheard and that was never possible but I guess it is impossible now.
We are in the thick of the Covid right now and the first acquaintance of ours has died from it. Know several young folks that have had it and recovered.
Kurt
