Brake fluid in Servo/booster
Wike
How do I get brake fluid out of servo/booster in my '74 TR6? Just replace M/C, but either the new M/C did not seal well, or, there already was brake fluid in servo from old M/C. Brake fluid on footwell floor..no dust cover under rubber boot on brake pedal assembly.
TR3driver
Great Pumpkin - R.I.P
Probably the best option is to remove the booster and have it rebuilt. Conventional brake fluid is somewhat corrosive and frequently the booster will fail soon afterwards anyway.
But last time it happened to me, I used a cheap venturi type vacuum pump linked to a Mason jar to create a kind of vacuum cleaner, and used that to suck the fluid out of the booster with it still mounted on the firewall. Seemed to work OK (although the car has been off the road for other reasons for a few years now, so I don't know if the booster still works today).
Dale
I think that if the fluid is on the backside of the diaphragm in the booster, then the diaphragm is already shot. The filter has nothing to do with keeping fluid in. It is there to keep big chunks out of the booster when the diaphragm moves towards the front and air is brought in to the booster.
bobh
Wike,
Something that is mentioned in the other replies, but needs to be more clearly stated.
Brake fluid cause 2 problems
1 It removes Paint
2 It is hydroscopic, attracts and combines with water
When brake fluid leaks into the booster it strips the protective coating of paint on the inside of the booster. Once the paint is gone and the coating of brake fluid mixes with moisture in the air. The inside of the booster will begin to rust. It won't take long for the metal to pit. Ultimately leading to the destruction of your booster from the inside out.
The same thing can happen to the bottom outside of the booster. If your old master cylinder was leaking at the bottom of the seal where the booster rod pushed the master cylinder rod into the MC. The fluid may have also leaked onto the outside of the booster, dripping down the underside. The paint will be gone, metal exposed to the ravages of hydroscopic brake fluid.
I agree with the comments from the others that you need to have the booster taken apart and fixed ASAP. If you are concerned that this is beyond your skills or do not have the tools Brosky mentioned. Ship it to the experts.
I'm in the middle of replacing my master cylinder and upgrading my brakes. My MC began to leak just a little at the bottom of the seal mentioned above. I suspect the initial leakage was very slight but as fluid accumulated it corroded the MC allowing more fluid to escape. Some began to drip down the bottom side of the boosted. It removed the paint and surface rust began to appear. I removed the MC and Booster. I found no evidense of fluid entering the booster. I thoroughly cleaned the outside of the booster with brake cleaner followed by several scrubbings with dish soap. Then removed all the paint with a wire wheel, wire brushed all surface rust until it was gone. Used a phosphoric acid gell (Aluminum jelly) to acid wash the surface twice. (To provide the paint with a freshly etched surface for better adhesion). Dried and painted with VHT Caliper paint, dried over night, then baked it for an hour at 175
Note: even with the scrubbing and hosing down at various steps I never saw any water come from inside the booster. I feel it was safe to assume the seals on the booster are intact and prevented leakage into the body. BTW. I've used the VHT caliper paint on other vehicles. Brake fluid does not affect it.
As fo my Master Cylinder I opted to have it sleeved and rebuilt by White Post. The price was more than the cost of an economy MC and less than the cost of a premium MC. I sent it to them on a Monday. It was back the following Monday.
My reason for the sleeving is that as the seals get old and start to weep brake fluid they will not attack the surface where the seal is made. Brass should not corrode like the original cast iron of the MC. If I'm correct I should not have to buy a new MC in the future. Only install a rebuild kit as the current one begins to age. WP recommends changing the brake fluid every few years. This should minimize the amount of moisture absorbed by the fluid.
White Post provides a writtten lifetime guarantee for their materials and workmanship. I'm sure this does not include the rebuild kit. I have no financial interest in White Post. I do have a considerable financial interest in my TR6! But I will say their service was excellent!
BOBH
SherpaPilot
Wike,
1 It removes Paint
BOBH
Bob: I just found this old post you wrote back in 2012. You addressed my concerns quite well. I looked up White Post and downloaded their info on sleeving. This looks like a long-term fix to the problem. Thanks
Rod-H
Bronze
Another thought is Silicone Brake fluid, Dot 5. Some people will most likely chime in and state how you can't use silicone or it will cause a rip in the space time continuum or some such. I've had good luck with it on all my British cars. It won't hurt the paint.
If you need a rebuild on your servo, I've used: Brakes Materials & Parts, 800 Sherman Boulevard, Fort Wayne, IN 46808, 260-426-3331.
I found them from the Buckeye Triumphs page- > Brakes — Buckeye Triumphs <. You can read the article about rebuilding the servo yourself, but, after reading it you may decide (like I did) it is safer to let someone with a lot of experience in brake servos do it.
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
6 Brake Fluid Spridgets 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
B General MG Brake fluid MG 7
R TR2/3/3A Brake Fluid Triumph 6
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
L 100/6 BN4 Brake fluid Austin Healey 17
M Losing Brake Fluid Austin Healey 8
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
petnatcar BRAKE FLUID CONTAINER for BT7 Austin Healey 0
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
tomshobby brake fluid leak? Spridgets 1
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
C Brake fluid? Austin Healey 10
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
DNK Copper in Brake Fluid Other Cars 2
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
