Although I would concur with Martin if panels are to be installing on his new and other very pristine frames with very little or no flex, I contend that most Healey frames have age deterioration which is not obvious. Externally obvious deterioration is usually corrected, however, internal frame rust deterioration and/or weld-attached panels are harder to identify and can, in most cases, be overlooked. In short, the engine and transmission can stiffen and reinforce the chassis and the running gear will allow the structure to sit as it will with stress placed as in all key areas expected. Yes, when stressed when driven and pushed, additional deformation with take place, however, some of this will be supported by the panels and taken up by the initial chassis pre-load. Yes, it is possible to get a good fit with without the weight as others contend and show proof of. However, why take the risk and why not install the panels after all is in place and not have the concern of destroying or scratching the shroud trying to slide the engine, possibly with the transmission, through that small opening? Installation with all open makes it much easier ... My opinion.
Ray (64BJ8P1)
