TR2/3/3A Best way to clean TR3 Bakelite horn button?
jessebogan
Try plastic polish and a soft cloth, or if it is really "patinated" use 4/0 steel wool with polish first.
K
karls59tr
Bronze
Sounds like it would work. Thanks Jesse 64 Chrysler Newport wagon! Now thre's an example of huge American iron. Probably bigger than the 57 Buick I used to have. :smile: Did they have the Slant 6 back then?
mgedit
I used Mother's Mag and Aluminum polish I bought at CTC (Canadian Tire). It is a paste and worked quite well (a very mild abrasive). I've not reassembled everything yet, but the horn push is still looks good after a couple of months of sitting. Cheers, Mike
Banjo
Brasso works wonders as long as it's not really dried up and porous. Very similar to the above mentioned Mothers product, maybe even a bit milder.
Don Elliott
I cleaned mine up with 1000 grit sandpaper and had it sprayed black with the same 2-pack black paint that the paint shop was using for the rest of my black 1958 TR3A. This was in 2007 and it still looks super.
TomMull
lbcs_r_fun
karls59tr said:
and maybe even shine it up?
Karl: Its easy to clean Bakelite, but you can't replace the resin that's gone. That's why the surface becomes rough with age and looks brown. As others have suggested you can have it painted it with a good quality urethane. However if you use a clear coat be sure the painter selects one of the u/v resistant types.
good luck, T
TomMull
good luck, T
It's possible that the makers of the Bakelite products used more resin on the surface or the process somehow "floated" the resin to the surface but even so, the samples I've worked on had uniform color throughout the piece and could be sanded and re-polished to the original (I think) sheen, or at least to look quite good. The cloudiness that polishing takes off is UV degraded resin and I tend to think the brown color may be too. Bakelite is not at all resistant to UV.
Most, if not all, modern automotive finishes have a very high degree of UV resistance, so I agree that paint would be a good option.
Tom
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
R General TR Best way to clean unpainted parts Triumph 1
D Best Way to Clean Corrosion on Fuse Clips. Jaguar 3
M What's the best way to clean off under-gunk? Spridgets 10
T best way to clean a canvass top? Triumph 4
jjbunn How best to clean up seat rails? Triumph 2
C What is the best way to clean out the fuel tank? Spridgets 26
danielnorton Best way to clean chrome/metal parts? Spridgets 11
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
JPSmit some days your best tool is a credit card Spridgets 2
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
