Tophatchef
I've got a 1989 xj6 with several warnings coming on the screen.
1. circuit 1 failure
2. circuit 3 failure
3. bulb failure
4. low break pressure
5. anti-lock failure
6. power fluid low
1. Circuit 1 Failure(I think) My right running light, right license tag light, and right light on the side bumper do not light up. Could this be from corrosion in the relay box? I tried to uncover the box, but found it to be too difficult, and wanted to know more before I proceed.
2. Circuit 3 Failure(I think because this one is new) I just removed my mineral oil reservoir, and it may not be properly reconnected to the electronic switch.
3. Bulb failure, caused by what I believe to be the circuit 1 failure.
4./5. Low Break Pressure/Anti-lock Failure, As previously stated, I had a leak in my mineral oil reservoir, and I now believe it to be fixed. Their was another type of brown/reddish liquid in the reservoir. Could this be the root of my problem, will it work itself out of the system. I believe I need a new brake accumulator, how important is it to have a functioning one on a scale from 1-10? Right now, my brakes are a bit hard to press, but considerably lighter since the fixing of my mineral oil reservoir.
6. Power Fluid Low, my power steering fluid is fine, is their another type of power fluid I am unaware of, or is my sensor just broken.
Thanks for the help
3. bulb failure
6. power fluid low
Thanks for the help
