1500 oil filter threads
Morris
Hey guys. I want grad a good deal I saw on ebay for an oil cooler kit, but I am not sure about the oil filter threads on my car. They are 3/4-16, right? I would go check myself, but I just had a vasectomy, and I am filling a bit puny at the moment.
thankee,
Morris
jlaird
Whoo hoo, you'll feel fine tomorrow. Watch TV, read a book or play here.
A 76 Midget 1500 Oil filter Spridgets 6
T Spitfire Oil Filter 1500 Triumph 1
T 1500 Oil Filter Triumph 2
G 1500 Oil Filter Question Spridgets 6
G 1500 Midget Oil Filter adapter Spridgets 1
T 76 midget 1500 oil pressure lines? Spridgets 15
T 1500 oil pan is off, what should I look for? Spridgets 20
boxfullofyertoys 1500 Oil Pressue Issues Spridgets 11
R oil feed kit for 1500 midget? negatives in this? Spridgets 5
dklawson Spitfire Crank Endfloat and Oil Pumps - Spitfire 1500 Triumph 9
bthompson 1500 front tranny oil seal?? Spridgets 14
T 1500 oil pressure gauge leaking Spridgets 6
pjsmetana Auxiliary Oil Feed to Rockershaft on 1500 engine Triumph 4
0 1500 oil cooler Spridgets 3
R 1500 with OD transmission oil recommendations Triumph 15
G What threads on 1500 oil sending unit? Spridgets 1
B 1500 Oil Cooler Spridgets 7
Morris Midget 1500 oil pan Spridgets 7
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
ronzet MGA Priming the OIl Pump... MGA 1500 MG 15
77_MG_Midget Triumph 1500 Motor Oil pressure question Triumph 8
R MG MIdget 1500 gear box oil changing MG 0
R MG MIdget 1500 gear box oil changing Spridgets 13
RobSelina Mocal 1500 oil cooler adapter part number? Spridgets 8
J Re: Oil Feed Kit for 1500 Spridgets 2
Thor Oil Feed Kit for 1500 Spridgets 8
J oil leak at timing chain cover 1500 Spridgets 2
G 1500 Midget Oil Pump Pinion Spridgets 1
78Z Spitfire Oil pressure in a 1500 Spitfire Triumph 9
aeronca65t 1500 oil pump Spridgets 4
J 1500 oil cooler MG 4
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
