77_MG_Midget
First, for those that read both the Triumph and Spriget posts like me, sorry for the cross post. But, my question may be best answered here, as this is the Triumph 1500 Motor.
Took my 1500 midget for a drive last night. After about 5 miles, I noticed the oil pressure wasn't quite what I thought it should be. Currently running 20W-50 oil.
Cold, it's 70 psi at 3000 rpm, 20 psi at idle. But after the engine warms up good, it drops to 45 psi at 3000 rpm and 12-15 psi at idle.
Engine temp is good at 160-165. The engine is fresh, only 25 miles on it so far after the rebuild. During the rebuild, I put in a new oil pump and pressure relief spring. Crank was cut .010 and the new rod/main bearings seemed to be within spec.
The workshop manual says the oil pressure should be 40-70 at "running speed" (which it doesn't define running speed, so is it 40, 50, 60 mph???) and 20 at idle. So, this made me a bit concerned as mine is lower at idle when hot.
Is this normal? I was reading a thread about making an adjustable oil pressure relief valve. Would this be worthwhile?
Advice is much appreciated!!!!
