Motor Jaguar 4.2
Timou14
Hello, I own a 1975 Panther that has a JAGUAR 4.2 engine, I have to do the engine maintenance, but I can't find the engine reference to buy the parts, can someone tell me where is the reference on the engine. Thank you for your help
Platinum
T
Timou14
Good evening, thank you for your link, but I don't know which Jaguar my engine fits on. I think it's an XK 4.2.
Platinum
T
Timou14
I changed the spark plugs, the ignition head, and yet it’s going bad in slow motion, what can it be?
Thank's and good day's
Geo Hahn
'Going bad' is a big vague. Can you describe the problem?
Also, if you provide the engine number that may better identify what you have. It may be stamped on the top of the boss where the oil filter head mounts.
LarryK
Look up parts for a 1974-75 XJ6 and compare with what you have. Unless they used junk yard motors, then they might be older. Fuel injection started late 73.
T
Timou14
Hello, thank you for your help, I found all the parts and re-ignition, but the engine 8L-547xx-S runs badly as if a cylinder is missing occasionally.
mezy
The Deville and J72. both had jaguar running gear, The Deville would have been a jaguar V8 or V12, They would have been sorced direct from Jaguar, The J.72 was an ultra-exclusive luxury roadster, the first production vehicle of the Panther Westwinds company.[1] Styled to evoke the Jaguar SS100 and sold from 1972 through 1981, it used mechanicals from the Jaguar XJ, including its 5.3 L V12 engine. It was also offered with Jaguar's 3.8 L and 4.2 L XK engines.[2]
You should be looking for parts to fit a 1972 + jaguar XJ
T
Timou14
Merci beaucoup de vos renseignements, je cherche écrou central de roues Panther, si vous savez où, merci merci merci
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
B Windscreen Motor Repair Restoration & Tools 6
HealeyPassion Pop Quiz: Displacement of 2912cc motor bored 30 thousands (0.030) over Austin Healey 3
W General Tech 2500S starter motor and fuse box questions Triumph 3
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
R TR2/3/3A TR3 Wiper motor Triumph 10
SNClocks Upgraded Motor Mounts Spridgets 4
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
M Engine Stand for 3000 Motor Austin Healey 7
E MGB MGB heater motor problem MG 3
edkap2002 TR6 starter motor advice Triumph 12
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Motor knocking at start up? Triumph 11
T TR2/3/3A wiper motor short Triumph 2
Darwin Spitfire Motor mounting help Triumph 1
3798j Off Topic My motor...it whistles... Triumph 2
60TR3A TR2/3/3A How Authoritative is the British Motor Industry Heritage Trust? Triumph 6
B TR4/4A Rubber wiper motor mounts Triumph 4
R Rewind electric motor Restoration & Tools 3
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
R GT6 Wiper Motor problem and time capsule Triumph 4
K TR2/3/3A Motor oil for Summertime Triumph 3
N TR2/3/3A Wiper motor armature Triumph 11
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
J TR2/3/3A Wiper Motor bracket Triumph 5
steveg Motor mount replacements Austin Healey 3
T TR5/TR250 TR250 wiper switch and motor Triumph 1
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
S TR2/3/3A starter motor Triumph 9
tinman58 TR5/TR250 TR 6 wiper motor Triumph 10
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
Michael Oritt Heater motor or switch problem Austin Healey 1
sparkydave Wiper motor '77 Spridgets 2
J TR2/3/3A Wiper motor wiring Triumph 4
