MGA Cleaned engine compartment on MGA - wont start now
Sheridan
I am new to this forum and new to MGAs. I just bought a 1959 MGA that has a 1800 MGB engine in it. I was doing some basic cleaning in the engine compartment and failed to cover the air cleaners. Yes - I am pretty sure I got water in the carbs. When I was done (everything looks really clean), the car started right away and ran enough to get 5 feet out of my garage then it started running rough and eventually stalled after a fantastic backfire. Now I cant get it started again. I have spark in all four cylinders. I am pretty sure this is because of the water I got in the carbs but have no idea how to even go about this. To be real honest, these carbs scare me a little bit (as I said, I am brand new to British cars). Anybody have any recommendations for me? Thanks in advance for your thoughts.
JPSmit
I very much doubt it is water. I suspect old gas, or a clog. Try starting it with starter fluid and see if it goes. How long was it sitting before you got it? And, welcome!
S
Sheridan
I have driven it about 200 or so miles in the past couple weeks and the gas is all new so I am pretty sure it is not bad gas but I have not ruled out a clog. The plugs were dry so it may not be getting gas. Is there a common place to check for a clog?
LarryK
Fuel filter! Carb float bowls!
Sarastro
A little water in the carb throat really shouldn't hurt anything. As much as I'm skeptical of coincidences, I suspect this might be one. I'd check for the usual fuel problems, plugged lines, stuck float valve, and so on.
Mickey Richaud
Seems this was a bit of a gremlin. Got in this morning and it started right up so I drive it to work (32 miles) with no issues. Odd....
Kidney stone passed!
:thumbsup:
Mickey
JPSmit
Mickey, may be right, kidney stone passed, however, if it happens again, it may be worth cleaning your tank - it may be a floating clog. Or gunk at the bottom.
Bossbill
He got water in his distributor cap.
This caused a misfire. Sure you had spark -- it just wasn't to the right cylinders at the right time.
After you let it sit the water that had condensed inside the cap evaporated and now it runs fine.
Always cover your distributor cap with Saran wrap or similar prior to cleaning.
There are lots of other parts that don't like direct hits of water either.
Air Filters.
Generator
Fuse box (although I laugh every time I say this about an MGA with 2 fuses)
Anything else electrical under the hood.
S
Sheridan
Air Filters.
Generator
Sounds perfectly logical!!! Thanks for the reply!!!
CJD TR2/3/3A Sorry...I think I cleaned out EBAY Triumph 17
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
