Changing the Oil on a 100-4
Pizzi348
I noticed I have a Purolator oil filter head - it seems like I just don't replace that with a new one? Sorry for being such an idiot, but how do I change the oil in my Healey?
mjobrien
Matt,
If this is the original oil filter, you remove the bolt at the bottom and remove the filter element inside. Be careful to note the way the parts come apart.
You can find a breakdown in the Moss catalogue or on line at
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=28850
If this an aftermarket replacement spin on you replace it like you would any late model car, sounds like that not the case but would suggest looking into a spin on adapter.
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29604
Hope this helps...
Michael.
glemon
It takes a LOT of oil, like 8 or 9 quarts if I recall correctly, at todays prices an investment in your motor, but worth it.
The cartridge type filter is a little tricky to get back on right, make sure the metal cannister is seated correctly before you tighten in back down or you will get the dreaded pool of oil below the car on start up.
P
Pizzi348
Wow great info. Thanks guys. Is there anything else I should do when I change the oil? I assume there must be something to grease.
glemon
Valvoline VR1 (look for the ZDDP sticker) is also a good choice and should be available locally, also there are other specialty oils like Brad Penn that have the ZDDP you need, not as big an issue if the engine is not recently rebuilt.
Keoke
Hi, it is a requirement That an oil with ZDDP be used in these flat tappet engines. However, with an eye to economy if your engine is well broken in and you do not flog it hard, Castro's GTX 20/50 can also be used. Similarly, any racing oil such as Valvoline VR1 is also usable. Other high quality motor oils can be fortified with STP to improve their ZDDP content.--Fwiw--Keoke
Johnny
I would suggest Matt, that you disconnect the battery first. The heavy cable connecting the starter to the solenoid is the battery lead, be very careful working that close to it.
The best procedure for working with the original, canister-type oil filters is to disconnect the filter AND head at the block, and perform the cartridge change on the bench. This way, it's easier to get the O-ring that seals the canister in its channel in the filter head. Of course, you'll need to get a new filter-head-to-block gasket.
Michael Oritt
Pizzi--
Take the car for a spin prior to draining the oil--hot oil drains better. If you have the original cannister, or if your spin-on filter element is in a vertical orientation, fill the cannister/element with fresh oil prior to reattaching.
Michael Oritt
I make a practice of cutting apart the filters to check the inside of the medium for metal bits or bearing material.
P
Pizzi348
Great good tips guys thanks.
Should I change the transmission fluid as well?
P
Pizzi348
Mike -
How many quarts of oil does it take?
Keoke
Should I change the transmission fluid as well?--- :yesnod: and get a factory service manual so you can properly maintain the car.
-----------------------------------------Keoke
glemon
While filling the cannister with oil prior to fitting is probably a good idea, I have never had the dexterity hold the bolt in to prevent leaks while manipulating the cannister around the frame rails and motor while keeping it vertical so oil doesn't spill out. See how you do taking it out while full of oil, that may give you some idea of whether you can put it back in that way.
Keoke
:iagree: Glempn.
I think you have all the trouble you need taking it off. However, if the entire assembly is separated at the block its less problematical. Similarly, putting it back empty and pressurising the system with the ignition key off is a better way to go.---Keoke
glemon
I am with you on that on Red Devil, I always spin it with the plugs out until I get some pressure on the needle, usually doesn't take long.
P
Pizzi348
If I have a modern spin on oil filter - do I still need to put oil in before attaching it?
Keoke
Pizzi348 said:
If I have a modern spin on oil filter - do I still need to put oil in before attaching it? ----
NO oil is not required in either case see the above posts--
:nonono:
P
Pizzi348
Ok one last stupid question - sorry. How do I pressurize the system with the ignition key off?
Thanks!
N Spitfire Changing Differential oil Triumph 14
bobh Changing Transmission Oil in 10 minutes Triumph 8
G Changing front oil seal on transmission. Triumph 14
B Changing Oil - Can't Remove Sump Plug - Size? Austin Healey 11
R MG MIdget 1500 gear box oil changing MG 0
R MG MIdget 1500 gear box oil changing Spridgets 13
W Changing Brake Fluid & Engine Oil Austin Healey 40
M Checking/Changing Limited Slip Diff. Oil on XJS Jaguar 2
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
A TR6 Changing bulbs in gauges Triumph 27
R Changing BJ7 Differential Ratio Austin Healey 10
T Kilmartin Changing Ownership Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
R TR2/3/3A Changing to a voltmeter. Triumph 6
red57 Changing Lock Barrels Austin Healey 15
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
R TR2/3/3A Changing rear seal Triumph 23
C changing ignition light bayonette Austin Healey 2
J Changing Brake Discs on my 63 BJ7 Austin Healey 9
R Rear quarter elliptical suspension changing Spridgets 12
F Changing fuel Austin Healey 6
drooartz MGB Changing clutch hose - tips? MG 13
T ?Changing BE to SU electric fuel pump Spridgets 8
J TR2/3/3A Changing fan belt. Triumph 9
A TR4/4A Changing rear diff seals Triumph 15
R TR4/4A Changing from 4 speed to Overdrive on a TR4 Triumph 18
D TR2/3/3A Changing polarity on TR 3 Triumph 9
O TR2/3/3A Changing Ignition Switches Triumph 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
M Changing coolant Triumph 14
P Changing Brake Fluid & Brake Pressure Switch Austin Healey 17
P CHANGING TO FRONT DISCs Spridgets 22
Reh Changing things up Triumph 13
af3683 Changing tires on Original TR 3 Wire Wheels Triumph 4
tweety Changing a half axle Spridgets 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Stewart Changing crossmember pads MG 2
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
M Brakes are terrible. Any tips on changing calliper Spridgets 14
theleisure Changing Out Front Bushings Spridgets 5
R Changing Motor Mounts Triumph 6
BritcarsUSA Changing 5/8 to 3/4 Midget filter adapter nipple? Spridgets 4
rchakr Changing Rear Springs Triumph 6
beaulieu changing an old car to E85 Restoration & Tools 14
T Changing fluids Triumph 16
G Changing bearings Triumph 7
B Changing to Silicone Brake Fluid Spridgets 18
