Timing Setup - Pertronix
Gary Pope
Does anyone know where the distributer timing should be set for a TR6 using Pertronix Ignitor?
I can't figure out where my distrib needs to be sitting at.
Also, the adjustment of the module to the magnet.. is it critical ?
Thanks
hkzimmer
Gary;
Timing is the same as with the points (4 degrees ATDC), dynamic. I don't know how critical the distance really is but I just checked mine, the module has 1/8 inch spacing at its closes point from the magnet. I also just removed the litte white sticker off the module, as it had started to peel off. Don't forget to regap your spark plugs to .030 inch from .025 if you havn't done so already. The one thing I don't like about the electronic timing is I can't determine engine RPM from the distributor/coil with my multimeter anymore. Does anyone have a solution for this.
Hans
G
Gary Pope
Hans, this may come as a surprize, but I could only get my car to run with timing set between 12 & 20BTDC, the latter being best. I don't have the vacuum advance connnected as it is not working. I have been fiddling with the distributer today .. moving it - driving - moving it - driving and so on. The distrib feels happy in about any position.
Rick O.
Hans
In my experience, the best way to time your six is by the seat of the pants. If you have the vacuum retard operational, strobe it in to around 4 BTDC. Then take it out and find an incline to labor the engine in fourth gear. Advance the distributor a wee bit and climb the incline. If you don't hear detonation (pinging), you're not quite there. The objective is to advance to detonation, then back it off slightly. Of course, you'll have to adjust your idle when you get to that point too.
Good Luck!
clint
If the module is close enough to trigger, it will be fine. They don't have to be as fine tuned as the LED or point types, and a bad bushing won't adversely effect it. Seat of your pants is how I time Brits too. Nail the gas in 4th., doing thirty. slight ping that goes away when you hit 40. Or, however you always timed it.
T TR4/4A TR4 Timing Cover Setup Triumph 3
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
A Timing cover access Spridgets 6
BN6_2197 BN6 Static Timing Austin Healey 2
vette Timing Marks! Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR4/4A New valve gears/timing Triumph 21
K TR2/3/3A Ignition Timing? Triumph 11
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
M 100-4 Timing Pointer Austin Healey 5
D TR2/3/3A Timing chain tensioner. Triumph 3
KVH TR4/4A No Marks on Timing Gear Triumph 30
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
vette MGB 74 1/2 Timing Specs. MG 16
B Timing Light question Austin Healey 0
F TR6 Timing adjustment Triumph 13
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
D BT7 Timing Advance Austin Healey 17
D BT7 ignition timing Austin Healey 5
R TR2/3/3A Timing Triumph 3
F TR2/3/3A Ignition Timing - Again Triumph 11
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
B Engine timing Spridgets 8
tinman58 TR2/3/3A Timing ? Triumph 21
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
F TR2/3/3A Timing with Electronic Ignition Triumph 14
D BT7 Timing chain install Austin Healey 2
