TR2/3/3A Timing marks on pulley?
Geo Hahn
My recollection is that there is only one mark -- TDC. It is a hole in the rearward lip of the pulley. Hard to miss though a dab of white paint is a good idea.
If the pulley halves have been assembled incorrectly then the mark may be wrong (off in some increment of 60 degrees IIRC).
JohnnyMead
I mark the 4 degree BTC. It’s a handy reality check. As Geo suggests, a bit of paint at the TDC hole is handy, I put it around the hole so it shows up well.
2liter4cyl
Bronze
I also put a dab of paint on the fan blade coming up when that little timing hole appears. Helps to see when the mark comes up. Also when jabbing starter relay when searching.
sp53
I find the mark by pulling #1 plug and leave the other 3 plugs in the engine. Then I put my thumb over # 1 hole and crank the engine. When the compression stroke comes up both valves will be closed and the air pushes my thumb off the hole and I stop cranking. Doing it this way the mark slips by about ¾ of an inch or so and I turn the engine back by hand to feel for the hole mark on the pulley because it is small, maybe an 1/8 diameter.
I do not remember if the 4 degrees is on slopped side or the straight side of the triangle fixed piece on the timing cover, but yes the hole in the pulley is about a ¼ inch away from the pointer at 4 degrees. The adjuster on the distributor with move the timing mark as it moves the points about 4 to 6 degrees either direction.
steve
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
19_again timing marks on pulley MG 7
A crank pulley timing marks Austin Healey 2
KVH General Tech Valve Timing--No Marks Triumph 20
vette Timing Marks! Austin Healey 12
KVH TR4/4A No Marks on Timing Gear Triumph 30
M Timing Marks Spridgets 3
jaegzie I have no timing marks anywhere on my 1275. Spridgets 14
S Timing Marks Spridgets 4
R timing marks Austin Healey 17
F Timing marks on the flywheel - 1100cc Spridgets 7
M Timing Marks Austin Healey 2
Jim_Gruber Timing Marks Spridgets 1
Brosky Clearly visible timing marks Triumph 7
T Dynamic timing marks Triumph 1
wkilleffer MGB MGB timing marks MG 6
T TR6 Does your TR6 have timing degree marks Triumph 21
M Timing Marks MG 6
Woodie timing marks, where are they Spridgets 11
M Timing marks MG 4
R Timing Marks Austin Healey 3
jtb55 Timing marks Austin Healey 4
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
A Timing cover access Spridgets 6
BN6_2197 BN6 Static Timing Austin Healey 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR4/4A New valve gears/timing Triumph 21
K TR2/3/3A Ignition Timing? Triumph 11
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
M 100-4 Timing Pointer Austin Healey 5
D TR2/3/3A Timing chain tensioner. Triumph 3
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
