The Roadster Factory Recovery Fund - Friends, as you may have heard, The Roadster Factory, a respected British Car Parts business in PA, suffered a total loss in a fire on Christmas Day. Read about it, discuss or ask questions >> HERE. The Triumph Register of America is sponsoring a fund raiser to help TRF get back on their feet. If you can help, vist >> their GoFundMe page.
Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
has anyone tried fiberglass leaf spings in their car? are these worth the money compared to steel? i see hyperco makes them also for the circle track guys. i am considering for my 1962 tr4.
rob
I saw a pair in a former SCCA nationals MGB (which is now a sorry excuse for a car ... ). They're a heck of a lot lighter than the originals (I got to hold one too as the suspension was being dismantled). However, I'd imagine they're fearsomely expensive.
I'm pretty sure that these have been around in Corvettes for a while (in the form of a transverse leaf in the rear)....did not know that they were avialable as an aftermarket item. CORVETTE COMPOSITE SPRING
I've seen composite leaf spring sets for MGBs at a couple of locations on the 'net. I know it doesn't really help you and your application, but I *think* the pricing was roughly double standard leaf spring packs.
As another option to throw into the mix, I've seen an outfit in the UK (can't recall their name ATM) that makes elliptical steel springs (again for MGBs) that offer a weight savings over standard spring packs, slightly more expensive then standard springs but less expensive than composites.
Sorry, I don't have any info for your specific application, but I thought it might be a little helpful to toss in at least one alternative option...
Yes, the composite spring I saw was a single leaf ... the failure would be equally catastrophic! Not to mention, I'd wager fiberglass has a poorer fatigue resistance than spring steel (but I don't know this for a fact).
Even multiple spring packs fail from time to time. Usually at the highest shear point... right at the mounting eye. Since the spring pack at this point is just one leaf... Don't see why a mono-leaf is any less safe. In any event, you still have the other spring and your shocks holding it together intul the ride comes to a stop.
actually, the fatigue resistance of the composites is far greater than steel (assuming the composite is correctly designed and made). steel snaps straight accross when it goes. composites (of the right design) don't fail that way.
they partially break,sag,bend. they don't just snap. multi leafs may break one or two but the others still hold everything together.composites have come a long way in 20yrs.
i worked for the forrest service when i got out of high school (a long time ago) repairing 4X4's and we replaced a lot of broken springs. most springs broke in the stack (99%)and not near the eye.
the dirt oval guys are the pioneers of the racing composite mono leaf and they did it because of the constant breakages and to go faster. those tracks get pretty rough.
flex a form do not show a thicker section near the axle mount which i find questionable. hyperco and the ones for the mg guys do have this detail.
rob
A steel mono leaf failure is sudden and can be catastrophic, as the break is essentially instantaneous. When a composite spring fails, it is more of a "greenstick" type of fracture. Think of breaking a dry twig as opposed to a green one.
Jeff
My buddies 1/4 elliptic Spridget broke one of the main rear leaf springs in the middle of a high-speed turn at Pocono last year.
This is the car I occasionally drive in enduroes with him.
I was following him at the time.....what a "joy-ride" he took!
Yep, steel springs break *very* suddenly!
I've experienced exactly ONE leaf spring failure. MGB. Instantaneous, and a fair o'l bit o' pedal stabbin' and "driver input" went on with that. I'd MUCH rather have a gearbox or engine scatter than have a rear end go squirrelly unexpectedly. Adrenal gland was already workin' in deficit, that put it into a week's worth of catch-up. sheesh.
How is it they never break while sittin' onna trailer?!
I was wondering about the panhard bar that is on my Pinto.
Seems it is a rather common mod. (Pinto has leaf springs)
I have had day-mares of going off the carousel at Nelson.
(Have you seen what is driver's left of the carousel) /ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/angel.gif
[ QUOTE ]
[/ QUOTE ]
from what I gather it seems to be somewhat common to do on Spridgets, too.
[/ QUOTE ]
Those "weeds" would be the tops of giant Cyprus trees growing out of a late Jurassic period swamp, hundreds of feet below track elevation. Supernatural creatures of heroic size quickly dispatch trespassers & play matchbox games with what is left of their vehicles.
There used to be neolithic cattle that romped around in that area. I've heard rumors that they are now extinct.
And, wonder of wonders, Nelson now has a real flush toilet.
Jeff
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
