FLEX A FORM FIBERGLASS LEAF SPRINGS
trfourtune
has anyone tried fiberglass leaf spings in their car? are these worth the money compared to steel? i see hyperco makes them also for the circle track guys. i am considering for my 1962 tr4.
rob
Matthew E. Herd
I saw a pair in a former SCCA nationals MGB (which is now a sorry excuse for a car ... ). They're a heck of a lot lighter than the originals (I got to hold one too as the suspension was being dismantled). However, I'd imagine they're fearsomely expensive.
Deleted member 3577
Never knew they existed.....
I guess if they make helicopter blades out of the stuff, they probably have it kinda figured out by now.
aeronca65t
I'm pretty sure that these have been around in Corvettes for a while (in the form of a transverse leaf in the rear)....did not know that they were avialable as an aftermarket item.
CORVETTE COMPOSITE SPRING
T
trfourtune
fyi, they charge $400 for a set. custom made to suit. not horribly expensive.
rob
Nunyas
I've seen composite leaf spring sets for MGBs at a couple of locations on the 'net. I know it doesn't really help you and your application, but I *think* the pricing was roughly double standard leaf spring packs.
As another option to throw into the mix, I've seen an outfit in the UK (can't recall their name ATM) that makes elliptical steel springs (again for MGBs) that offer a weight savings over standard spring packs, slightly more expensive then standard springs but less expensive than composites.
Sorry, I don't have any info for your specific application, but I thought it might be a little helpful to toss in at least one alternative option...
T
trfourtune
problem with steel mono leaf springs is that when and if they break it is catastrofic. that's why the search for composite.
rob
Nunyas
ah! I did not know that... learn something new every day /ubbthreads/images/graemlins/smile.gif
thanks for the info
Wouldn't a break from a composite spring be catastophic too?
I remember them being available for lowrider pickup trucks too - many moons ago when I would buy those magazines.
Matthew E. Herd
Yes, the composite spring I saw was a single leaf ... the failure would be equally catastrophic! Not to mention, I'd wager fiberglass has a poorer fatigue resistance than spring steel (but I don't know this for a fact).
mjamgb
Even multiple spring packs fail from time to time. Usually at the highest shear point... right at the mounting eye. Since the spring pack at this point is just one leaf... Don't see why a mono-leaf is any less safe. In any event, you still have the other spring and your shocks holding it together intul the ride comes to a stop.
T
trfourtune
actually, the fatigue resistance of the composites is far greater than steel (assuming the composite is correctly designed and made). steel snaps straight accross when it goes. composites (of the right design) don't fail that way.
they partially break,sag,bend. they don't just snap. multi leafs may break one or two but the others still hold everything together.composites have come a long way in 20yrs.
i worked for the forrest service when i got out of high school (a long time ago) repairing 4X4's and we replaced a lot of broken springs. most springs broke in the stack (99%)and not near the eye.
the dirt oval guys are the pioneers of the racing composite mono leaf and they did it because of the constant breakages and to go faster. those tracks get pretty rough.
flex a form do not show a thicker section near the axle mount which i find questionable. hyperco and the ones for the mg guys do have this detail.
rob
Bugeye58
A steel mono leaf failure is sudden and can be catastrophic, as the break is essentially instantaneous. When a composite spring fails, it is more of a "greenstick" type of fracture. Think of breaking a dry twig as opposed to a green one.
Jeff
aeronca65t
My buddies 1/4 elliptic Spridget broke one of the main rear leaf springs in the middle of a high-speed turn at Pocono last year.
This is the car I occasionally drive in enduroes with him.
I was following him at the time.....what a "joy-ride" he took!
Yep, steel springs break *very* suddenly!
Platinum
I've experienced exactly ONE leaf spring failure. MGB. Instantaneous, and a fair o'l bit o' pedal stabbin' and "driver input" went on with that. I'd MUCH rather have a gearbox or engine scatter than have a rear end go squirrelly unexpectedly. Adrenal gland was already workin' in deficit, that put it into a week's worth of catch-up. sheesh.
How is it they never break while sittin' onna trailer?!
Deleted member 3577
I was wondering about the panhard bar that is on my Pinto.
Seems it is a rather common mod. (Pinto has leaf springs)
I have had day-mares of going off the carousel at Nelson.
(Have you seen what is driver's left of the carousel) /ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/angel.gif
Platinum
heh...not "lately" but I suspect it ain't changed in the last twenty years. "Weeds" would be a kind description. Downhill too, IIRC.
Nunyas
[ QUOTE ]
[/ QUOTE ]
from what I gather it seems to be somewhat common to do on Spridgets, too.
Deleted member 3577
[ QUOTE ]
[/ QUOTE ]
Those "weeds" would be the tops of giant Cyprus trees growing out of a late Jurassic period swamp, hundreds of feet below track elevation. Supernatural creatures of heroic size quickly dispatch trespassers & play matchbox games with what is left of their vehicles.
Bugeye58
There used to be neolithic cattle that romped around in that area. I've heard rumors that they are now extinct.
And, wonder of wonders, Nelson now has a real flush toilet.
Jeff
T flex a form fiberglass leaf springs Triumph 2
jfarris For Sale FREE 83mm flex hone - item claimed Triumph Classifieds 1
W replace rigid master cylinder lines with flex. Spridgets 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
J TR4/4A Upper steering flex coupler Triumph 4
M TR4/4A Reducing rear chassis flex. Triumph 3
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 73mm Brush Research Flex Hone Triumph Classifieds 0
wangdango XKE clutch flex line/firewall? Jaguar 1
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
H larger flex fan Austin Healey 2
fpstude TR2/3/3A Flex Oil Line to Oil Pressure Gage Triumph 5
M_and_P A bit of flex British Motor Corp 5
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
J Front fender flex ??? Triumph 15
D Oil pressure gauge flex hose. Spridgets 29
F Chassis flex during panel replacement Austin Healey 7
I Bristle flex seal help please Spridgets 0
SkinnedKnuckles TR6 TR6 Steering Flex Coupling Triumph 7
G Texas Cooler Versus Flex Fan Austin Healey 20
livinginthepast 948 Fan flex? Spridgets 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
TonyPanchot TR5/TR250 250/6 replacing rear flex brake hose Triumph 5
svtmikey Metalastic versus generic Roto-flex couplings Triumph 5
J thread count on the fuel line to flex line Austin Healey 9
B Flex Fuel Line Leaking Austin Healey 7
G Frame Flex Triumph 19
Atrus Flex brake line to rear axle Spridgets 2
N TR6 Installing Flex Coupling for steering TR6 Triumph 5
startech47 Flex fan on 1500 Spridgets 6
M XJ6 flwheel ring gear smaller than flex plate ring Jaguar 5
T TR6 tr6 body flex Triumph 3
B Progress Up-date - Shell "Anti-flex" Supports MG 7
T TR4/4A Flex Couplings [4a Steering] Triumph 10
K Frame and Body flex ??? Triumph 9
G How much frame flex is normal? Triumph 8
G Flex Fan..... Triumph 2
petnatcar Compression Test Record Form Austin Healey 0
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
anarchy99 Some form of a poor Vette... Spotted 1
M T-Series Looking for a picture of my MG-TF V8 form the sixt MG 1
M TR6 My TR6 Fresh form the Body Shop [video] Triumph 5
bobmga62 MGA Tube Shocks form MGB to MGA MG 4
AltaKnight New Life Form? Triumph 3
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
R After market 3000 fiberglass hardtop Austin Healey 13
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
Editor_Reid Securing Bugeye Fiberglass Bonnet Spridgets 15
