TR2/3/3A Headlight Hi beam floor button fail?
Sarastro
I normally don't recommend replacing electrical parts without making some tests to isolate the problem, but in this case I can't imagine much except the switch.
I assume that the hi beams stay on when you push the switch, and the lows just don't come on. If the hi beams go off but the lows don't come on, that could be the low-beam wiring from the switch.
RandyInUtah
Yes I would check the connections of the wiring before replacing the switch. Then again you might take the switch out and make sure it is functioning properly. On my own car I found a loose connection in the bullit connector.
Graham H
I went to get in the car one day and found the outer button and innards of the switch on the floor, the rivet holding the outer button had come out. I ordered a new one from the usual suspects and found it created a delay when changing from high to lo which suggested to me that it may not make good contact and the lights may go out so i put the original back together with a pop rivet to hold the button back on. It's been working as it should for the last 8 or 9 years if you can't fix it try for a second hand original rather than the after market ones on offer.
Graham
CJD
That is the only switch in the TR3 that I could not rebuild. I had to buy a new one when mine died.
Graham H
If you drill the rivet out in the centre of the cap all the innards will spring out that's what happened to mine and left greasy marks on my new carpet into the bargain.
Graham
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
longbridgehealey Headlight low beam Spridgets 5
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
Healey Nut Headlight buckets Jaguar 3
B Headlight Dip Switch Austin Healey 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Guido36 LED Headlight Upgrade Austin Healey 1
Healey Nut TR6 Headlight size Triumph 58
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Spock TR6 '72 Headlight Relays Triumph 4
Upland 3 position headlight switch is now 2 Spridgets 1
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
D TR2/3/3A Headlight Trim Triumph 17
P TR6 ^%$#headlight rim Triumph 4
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
P TR6 Headlight problem Triumph 3
M Headlight relays Austin Healey 17
T TR4/4A Attaching headlight trim ring Triumph 6
S TR4/4A Headlight switch wiring. Please help Triumph 2
GTP1960 TR2/3/3A LED headlight question Triumph 11
K TR4/4A 4A chrome headlight rim installation? Triumph 2
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
S TR2/3/3A Tr3 headlight buckets Triumph 3
healeyblue XK 120 headlight mounting Jaguar 1
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
4tecdog Headlight relays the easy way Austin Healey 13
M For Sale E-Type S1 Plexi Headlight Covers Jaguar Classifieds 0
Rut Headlight relay question Spridgets 3
JPSmit Question four - headlight trim ring Spridgets 9
princetn1 MGB Headlight Grille MG 7
TomMull General Tech Headlight upgrade Triumph 9
S Replacement Headlight Switch Spridgets 4
jaegzie Headlight buckets Spridgets 3
B Sizes of Headlight Bucket Recess Austin Healey 8
CJD TR2/3/3A Headlight bulb rating Triumph 18
Tinkerman TR2/3/3A 1960 TR 3A square spier nuts on headlight assembly Triumph 2
