Possible Mini Gauges?
debracrow
Hi, new member, have had various English vehicles over the the last 45 years. I have a question about a Instrument Cluster I have had for years. Every so many years I drag it out and try to ID it with little success. The Speedometer is a Smith's marked SN4418/00. The only reference I have ever found said it was for a Mini(which may or may not be true) but nothing more. I have looked at a lots of BMC dashboards and the only thing even close is for the Moke. It may not even be for BMC. It has a voltage stabilizer on the back, which I think was introduced somewhere in the mid 60's. The front panel is metal with wood grain finish. Any help would be appreciated. Thanks in advance. min5em.jpgmin3em.jpg
Google picture search shows it is out of a 1970 Austin 1100 (or something similar). The hole in the upper left corner is where the key should be.
dklawson
Can you also post a picture of the back?
It is not a "stock" Mini assembly and appears to be part of an aftermarket wooden dash. "Rokee" is the most common wooden dash but the layout of the switch holes and lack of 2" gauge holes says that's not what you have.
The gauge itself would be for any number of possible "non-Cooper" and "non-S" Minis. There should be an additional 4 digit number near the odometer window. Those 4 digits define the "turns per mile" number and will help identify what cars the gauge is suitable for.
The picture shows a "sharp edge" bezel on the speedometer and four (4) tightly spaced Philips (or PoziDrive) screws. That identifies the gauge and panel as for/from a Mk1 (up to 1967). The fuel gauge is the voltage stabilized type which means it is suitable for Minis built from 1965 on.
debracrow
Thanks for the info so far. I could only find one photo on the internet showing a panel of the suggested vehicle looking through the steering wheel with the door open, not great photo or angle.
dklawson
Thanks for the additional pictures. I'm afraid I cannot add much to what I posted earlier.
The voltage stabilizer and the "sharp" bezel on the front say it is a Mk1 speedo made between 1964 and 1967. The 1376 and 90 MPH scale identifies this as a speedometer used by regular Minis (not a Cooper or -S).
The angle drive on the input is not stock for the Mini and was probably required because of that custom wooden dash center section. I have not seen that particular design center wood panel.
Tagus
I have a 1967 Moke and my numbers are a match to yours. Not sure what the dash would be out of? There were companies in the 60's such as Radford that upscaled the Mini but from what I found they had more gauges. The 4 screws in the front say it bolted up to the bezel frames used the 60's Coopers or Super Deluxe Mini.
deconstruction
Like debracrow, the shape and layout of the panel suggests to me ADO16 Austin 1100. Perhaps someone has made a wafer of real wood and fitted it to the 1100 panel?
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
