TR6 PDWA Issue
Martin Secrest
My PDWA shuttle is off-centered, and has been for a few years, just finally getting around to this and other things. I'm not really familiar with this item. I'm pretty sure it's moved to the rear brake side, because when I remove the plastic switch, I see a small gap to the right that I can just barely get a small point into. However, I cannot get it to budge to the left with the tool. So it occurred to me that opening a front bleeder might help .. nope. So just now I asked my son to press the brakes while I again opened the left front bleeder, we did the routine twice, still no shuttle movement.
Thoughts? Hoping it's not stuck b/c of my neglect, and that I don't have to R+R it. Thanks.
Martin Secrest
Arlington, VA
72 Triumph TR6. It's cool.
M
Martin Secrest
I guess the shuttle is jammed to one side. Next thing I'll try is opening both front brake bleeders and try centering the shuttle again with the brake pedal. For those with experience, is this more easily accomplished with two brake bleeders open, rather than just one, as I've already tried (and failed with)?
Also, am I correct that the little tiny gap I'm seeing thru the switch hole on the right side of the shuttle (and into which I can get a tiny tool) means that that is the side to which the shuttle has moved? I don't see the same gap on the left (front brake) side of the shuttle thru the switch hole.
poolboy
Trace back the hydraulic line from the PDWA to the Master Cylinder.
The forward line on the M/C is for the Rear brakes...Knowing that might help you determine to which end of the PDWA the shuttle shifted.
M
Martin Secrest
Right, I did that, and on my '72, looking down at the PDWA, the rear brake lines are to the right, the fronts to the left. As best I can tell the shuttle has moved right, so I've been bleeding the fronts, but to no avail. I'll try the rear on the off chance I'm wrong, but I think I just have to pull the unit and rebuild. ****.
dklawson
Hopefully some of the links below will prove helpful as you work through the PDWA.
From the Buckeye Triumphs website:
https://static1.squarespace.com/sta...058350/Overhauling+Master+Cylinder+&+PDWA.pdf
If you find after working on the PDWA that you need to machine a new piston for it to use o-ring seals... see the archive link below from Buckeye Triumphs:
http://web.archive.org/web/20030506...yetriumphs.org/technical/Brakes/PDWA/PDWA.htm
And from restoration blogs:
https://72triumphtr6.wordpress.com/...setting-pdwa-to-fix-bright-lightoil-light-on/
and
http://www.74tr6.com/pdwa.htm
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
M TR6 PDWA valve Triumph 6
S TR2/3/3A Pdwa Triumph 6
M TR6 Early vs newer pdwa for Tr6 1975. Triumph 3
SherpaPilot TR6 PDWA Leak Triumph 7
M TR6 Pressure differential warning assembly PDWA valve Triumph 4
brgrmyster GT6 What's the purpose of the ball bearing in the PDWA switch? Triumph 1
sparkydave PDWA rebuild Spridgets 13
R PDWA Wiring Triumph 29
I PDWA switch rebuilding help Triumph 12
Scott_Hower PDWA; tips for getting the shuttle out of it. Triumph 3
I TR6 TR6 PDWA switch help please Triumph 10
hondo402000 wanted Hazzard bezel or PDWA warning bezel. 71 TR Triumph 0
hondo402000 PDWA Rebuild Triumph 18
dklawson PDWA Switch Terminals & Rebuild Triumph 6
T Is the PDWA selt-centering? Triumph 6
MTribe PDWA leak - how to fix? Triumph 6
Brosky PDWA & Rheostat Rebuild pages competed Triumph 6
red_tr250 Stag Stag PDWA vs TR6 Triumph 2
D PDWA switch? Triumph 15
jjbunn PDWA Seal Bolt Removal Method Triumph 12
jjbunn Brake Master Cylinder and PDWA Questions Triumph 11
B PDWA switch query Triumph 2
Brosky PDWA De-Mystified Triumph 29
A Permanent fix for PDWA brake switch Triumph 19
SpannerMan TR6 Source for TR6 pressure switch [pdwa] rebuild kit? Triumph 21
Scott_Hower Sectioned PDWA photo MG 24
G Gonzo PDWA valve Triumph 30
71tr PDWA Valve O-Ring Material Triumph 6
cutlass29 Spitfire spitfire mk3 '70 brake pressure switch pdwa Triumph 1
Scott_Hower Radiator back in and brake PDWA leak MG 3
77MidgetMkIV PDWA rebuild Spridgets 7
tr6web TR6 PDWA switch TR6 Triumph 5
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
T 100 BN2 Possible Ignition Issue Austin Healey 7
B MGA Tach drive issue MG 1
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
J Issue with Reverse Spridgets 2
Celtic 77 MGB Seized air pump issue MG 25
H TR4/4A Advise asked on TR 4 a frame collision/issue Triumph 20
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
B General MG Turn Signal Issue MG 1
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A Brake issue? Triumph 8
M TR6 Alternator Issue for 72 TR6 Triumph 7
A TR6 TR6 Distributor cap issue Triumph 4
EricJNewman MGB Weird Brake issue finally solved. MG 1
B Any issue with cutting this weld on the spring base plates? Spridgets 4
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
