Clutch fluid
So my bugeye drove home the other day with no problem. The next morning no clutch and master empty. Where to start? We’re moving to the gulf coast in two weeks and I was just going to drive it over
LarryK
Any puddles under the master? Look under dash at rod area and check boot for leaks. Then under clutch for puddles. If fluid is lost, has to be dripping of flung somewhere.
Jim_Gruber
Or just maybe a slow leak and you ran out of fluid. Too it up, bleed the clutch, and pack an extra can or two of brake fluid. More important you are sharing that reservoir with your brakes. It might be a leaky wheel cylinder. Hey where are you moving. A few good KBC Shops in Tampa area.
longbridgehealey
Thanks guys, trying to fit it into the schedule, I really don’t want to trailer it over.
Jim, I tried to send you a message when you moved to FL, but I guess my forum message skills aren’t the greatest! I’ll get in touch when we get over there, maybe you can connect me with some of those shops. I was talking to a few of the folks from the Tampa Bay Healey club on Saturday (they did a run to The Villages monthly car show. Dave (?), I think his name was, the President, mentioned that you were a transplanted northerner who was now a member. Take care,
Larry
Jim_Gruber
Larry lots of LBC activity down here. Unfortunately most of the activity is over across the Bay in St Pete or Clearwater. You need to drive up close to Crystal River to get some elevation changes but there are quite a few backroads you can get lost in if you drive towards the center if the state and Southeast. So where are you moving to, what area?
longbridgehealey
Hi Jim, moving to Palm Harbor, south of Tarpon Springs and just north of Dunedin. Ten minutes from Courtney Campbell causeway. I think we will be across the bay from you.
Jim_Gruber
Larry, about an hour away with good traffic. Kate and I got a chance to check out Dunedin a few weeks ago. Next Artsy Community. Great Metal Working Shop there that they can turn out just about anything or if you need help with removing that broken bolt. Even a Bridgeport Milling machine you can get access to. Great Mexican Resturant in town by the Park in town. We really like that area. Tampa Bay Austin Healey Club meets on 2nd Saturday 8:00 am at Daddy’s Grilke in Oldsmar and
the Tampa Bay British Car Club meets at Paradise Diner in Safety Harbor 6:00 pm on 1st Thursday. You will be right in the heart of a tremendous amount of LBC Activity. Hey drop me a note when you get here and I can get you connected. Both groups have websites and there are quite a number of social events and drives. Unfortunately most are not on this side of Tampa Bay. It’s easier to get to Sarasota than over to your area. Welcome.
longbridgehealey
Great, thanks! Will be in touch.
Lin Brake/Clutch Fluid Austin Healey 11
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
toysrrus TR6 Clutch fluid question Triumph 4
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
RJS TR4/4A Clutch Fluid Very Dark After One Year Triumph 5
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
B Clutch pedal no fluid? 2 -3 years of sitting... Spridgets 30
richberman brakes/clutch fluid out top of brake reservoir Austin Healey 11
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
G T-Series Clutch fluid MG 2
D Mysterious clutch fluid loss Triumph 9
knad2208 Hydraulic Clutch Fluid Spridgets 1
Bruce_B Fluid for MC Brake and Clutch?? Synthetic--REgular Spridgets 4
B What Kind of Clutch Fluid? Spridgets 4
zimmy clutch fluid types Spridgets 4
I TR6 Correct clutch master cylinder fluid for 69TR6? Triumph 5
F Brake and clutch fluid 73 TR6 Spridgets 9
VelodromeRacer Clutch fluid to run... Racing 5
Rob_P T-Series Ugh, clutch fluid all gone... MG 12
X T-Series Sooty exhaust pipe & loosing clutch fluid MG 0
BritCarFan Silicone brake and clutch fluid British Motor Corp 7
H BRAKE/CLUTCH FLUID Triumph 28
P Clutch fluid query Spridgets 1
H Which Part of the Brake Fluid Canister for Clutch? Austin Healey 8
C T-Series Brake/clutch fluid MG 9
S Clutch Fluid Mystery Jaguar 2
T reminder-brake & clutch fluid Triumph 16
tr6web Brake versus clutch fluid Triumph 14
D T-Series Question on clutch fluid and pedal MG 4
P Ran out of Fluid...Clutch Pedal Pressure... Austin Healey 10
S T-Series Where did my clutch fluid go... MG 7
S T-Series brake & clutch fluid MG 2
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
