T-Series Where did my clutch fluid go...
srmorse
Uh oh...
Went for my first spring visit to the MGB to do do a bunch of tune-up things.
First thing I noticed was the clutch pedal felt awful strange...and after starting, it was clear that there was no clutch at all. I opened the master cylinder and there seems to be no fluid at all in it...although the cylinder itself looks pretty much brand new. There was another car on the lift, so I couldn't get a good look underneath, but there was no spot on the ground under the car. It's been kept in heated storage all winter, and the clutch was fine when I parked it in November.
I just bought the car last September and have a bunch of receipts. None mention the master (which looks new), but there was a replacement of the slave hose almost 2 years ago. My first guess is the slave is shot...but why don't I see a puddle?
If it is likely the slave, should I attempt to rebuild it, or is it generally better to replace it?
G
they are cheap replace it, but if you don't see fluid, it's probably the master cylinder, check the floorboards around the driver's feet
urchin
I once had a Triumph Spitfire which sat for a winter. When I went to move it, the clutch master was empty. The fluid can evaporate and unused clutch rubbers can harden and let air in to complete the evaporation. I filled it, bled it, and eventually had a clutch action restored. The moral is not to let the car sit. I drove my Spitfire and my MGB year round and they benefited from it.
Jeff Aronson
Vinalhaven, ME
SteveT
I have the same problem with my brake master. The rear reservoir is completely dry with no signs of leakage. There is nothing on the floor of the car or the floor of the garage; the only other place might be the rear drums? But there are no puddles around any of the wheels or anywhere in the garage. Can hydraulic fluid evaporate?
Fox
I've never heard of it eveaporating, but maybe it can? i think you should first try bleeding the system to remove any air (hardened rubber seals will let air in over time) then you will see what will happen, if it will drip out or not!
Dave Russell
Yoda - R.I.P
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Fox:
I've never heard of it evaporating, but maybe it can? <hr></blockquote>
In the experiment I tried, fluid sitting for a long time in an open container, it didn't evaporate but actually gained some volume from moisture pick up.
S
srmorse
Well...got back up to work on the car and topped up fluid and pumped the pedal several times just for ha-has to see if I'd get any pedal. Still nothing, so while I was working on replacing the fiber washers on the fuel pump (a leak there as well) I noticed brake fluid collecting on the outside of the slave cylinder. I pulled the slave and inside was pretty pitted and the internal seal had completely disintegrated. The push rod was also very badly scored, so although I had a replacement slave cylinder, I dodn't replace it as of yet until I get another push rod.
Hopefully that will do it...I'll give an update when I find out...
S
srmorse
well...got the replacement pushrod and put everything back together. Bled the system and I had clutch again! Unfortunately I couldn't take it for a test ride to be sure all was OK (entrance was blocked). But I was able to get into all gears and everything felt better.
Next time I'll get there will be a week or so...so I'll keep my fingers crossed and see if I still have pressure when I get back...
warwick-steve Where did the smell go? Austin Healey 11
R Where did it go? A who-done-it mystery! Austin Healey 18
Jim_Newman Where did I go wrong? Austin Healey 37
M where did it go Triumph 2
B TR2/3/3A Where did I see the picture of the TR3 bulkhead Triumph 6
T where did my coolant go? Austin Healey 5
M Where did my horn go?? Spridgets 4
KVH Where Did They All Go? Triumph 5
Stewart So where did you take your B today? MG 6
mgblue79 Where did the summer go? Spridgets 23
jlaird Where oh where did Jaybird go? MG 51
jsneddon TR2/3/3A Where did all my TR3 bottom end power go? Triumph 6
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
