TR2/3/3A All new valve train - no adjustment at rocker arms
smading
'57 TR3
I have a completely rebuilt engine with new cam (improved performance cam from Moss), new push rods, new rocker arm assembly, and new valves with hardened seats in the head. All parts sourced from Moss.
After bolting the rocker arm assembly in place, there is zero clearance between the rocker and valve stem with the adjusters backed all the way out. Are the pedestals the same height on all TR3s? I don't have my old ones unfortunately to compare.
Anyone had this problem? What's a good fix?
TR3driver
Great Pumpkin - R.I.P
Pedestals should be all the same, but it sure wouldn't be the first time that new parts are simply wrong.
Another cause is the head having been cut down, to increase compression ratio. The usual cure for that is to fit shorter pushrods (available from most of the "performance" suppliers, not sure about Moss).
It's not likely that the valve seats were installed too deep, or are recessed already, so I think it has to be one of the two above causes.
BobbyO
I think Randall's probably right about new parts being wrong. The quality at Moss seems to have gone down. Items I recently purchased include the windshield sprayer opening located so, if used, all it would do is put water on the bottom of the windshield. I had one original and needed another only to plug the hole. I don't intend to use them so it didn't make any difference. Also, the rubber around the door, both top and bottom is now a lot smaller than it was several years ago when I did another car. I still have that car so the comparison was easy. Anything to reduce cost.
Again, as Randall said, the head could have been shaved. Years ago I received a head, along with numerous other parts, that I was told had been shaved and rebuilt. Some years later I had a burned valve so decided to use the "rebuilt" head I had. It had been shaved so much that I couldn't even bolt down the rocker assembly. Shorter pushrods or thicker head gasket would have been required. Just had the burned valve head rebuilt and still have the shaved head.
sp53
My guess is shaved head. Can you measure the thickness of the head at bottom? The head steps down at the bottom by the push rod tubs and when they are shaved that much you can measure it with a ruler and see the difference. If I remember correct, they are supposed to be like 3/8, but I would have to measure to be sure.
steve
TomMull
STeve 1958
Would it be possible (advisable) to grind the push rods down a 16th. This is more of a question than an answer. In 1974 I had to buy a thicker head gasket to reduce the compression. Might still be available but only gains you a 32nd.
Steve
TomMull
Not advisable IMO but I am an amateur builder at best. You'd need to retain the radius of the end as well as the balance or weight and I'm not sure 1/16 would suffice. Also don't know haw hard the ends are or how much metal there is in them. I suppose if you've got a decent lathe you'd have a chance.
Shorter pushrods are available at a reasonable, I think, cost, all balanced and correct, and that's certainly the way I'd go.
I also think some of the original push rods can be shortened by taking the ends out, shortening the tube and putting the ens back in, but I've never tried it. The newer ones don't come apart.
Tom
TR3driver
The metal isn't thick enough to just grind down. With some push rods, though, the cup end is a casting which you can remove, cut some from the tubing, and reinsert the casting.
A set of shortened pushrods is only $85 at BFE, though. Given the mess if one fails, and the work involved, I would (did) just go for a new set. The new pushrods are also stronger than stock.
martx-5
Stock head is 3.330". I milled 0.085" from my head and had to use shorter pushrods. I got them from British Frame & Engine.
G Valve Train Lubrication Austin Healey 1
C Ford pre-crossflow valve train Other British Cars 2
bertl TR2/3/3A TR3 Valve Train Pedestals Triumph 5
chrpark disassembling/cleaning valve rocker train Spridgets 5
M TR2/3/3A Valve Train Noise TR3A Triumph 2
thechileman Valve train noise Triumph 11
T Valve Train Failure Triumph 30
Z Noisy valve train in rebuilt motor? Plus pics... Triumph 4
E TR6 TR6 Valve Train Specs Triumph 0
D Valve train noise Triumph 14
jtb55 valve train oiling Austin Healey 2
M Valve Train Clearance Spridgets 14
78Z Lotus Engineering's Fully Variable Valve Train Lotus 8
J New healey 100 owner start up Q'S . Valve train Austin Healey 6
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
