Body Parts Code
BJ8Healeys
Hello, Healeyphiles -
During assembly of the bodies of Healeys at Jensen Motors, a number was stamped in three places: on the fixed part of the bonnet latch, just in front of the radiator; on the driver's side bonnet flange to which the hinge is bolted (LHD cars. Maybe passenger's side for RHD, but I don't know), and on the tab on the underside of the boot lid to which the prop rod is attached. This number generally has a preceding letter followed by one, two, or three numerical digits (e.g., P429). The general consensus is that these numbers were stamped to ensure that the parts so stamped stayed with the car during subsequent disassembly/reassembly of the parts at Abingdon (e.g., removal of a bonnet to install the engine) because Jensen matched and adjusted them for best fit with the chassis.
As a part of the BJ8 Registry's contribution to our knowledge and understanding of how things were done at the factory, I have been documenting as many as possible of these numbers (which I call the "body parts code"). My initial goal was to see if there was a pattern that could be used to identify the car that originally had that part. Unfortunately, as with so much of this data, there is no strict correlation between increasing body parts code numbers and the chassis numbers, but it is possible to get pretty close. The more of these numbers I can document, the better the results will be.
I have a rather early BJ7 (20111) that has the body parts code A936. The earliest BJ8s have the letter E (the 10th BJ8 chassis, 25324, has E10). I need more information about when these numbers started (model, body parts code). It is also helpful to document the batch and body numbers from the body plate in the top center of the firewall.
I am requesting that you send this information to me if you would like to participate in this project to increase our collective knowledge. For all 3000s, I would like:
Chassis number from VIN plate
Batch and body numbers from body plate
Body parts code from latch, hinge, and boot lid
If you know the build date(s) of the car, that would be helpful, too.
Please send direct to me at: sbyers@ec.rr.com
Thanks!
Steve Byers
BJ8 Registry
BJ8Healeys
BJ8Healeys
Thanks!
Steve Byers
BJ8 Registry
Really, Forum Members? After 11 days and 184 views of my post and request for data, there has been exactly ONE response to my request. Why? Wasn't I clear enough about what I wish to get and what the data can do for the Healey community? Can't we do better than that?
BJ8Healeys
BJ8Healeys
Your email link does not work for me. I found E49 in the boot.
Don't know what that problem is, Tahoe Healey. When I click on the link, it opens a new email message to myself. Did you try typing it into an email yourself?
Steve
Jerry
I sent my information to you about an hour ago. but the body number plates are not on the car. I am pretty sure they are in a box somewhere but I have not found them yet. I did give you the VIN number which I know you have in your records already.
Jerry
BJ8Healeys BJ8 Body Parts Code Austin Healey 5
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
R TR6 Body Parts Source, Upper Midwest Triumph 6
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
BJ8Healeys Mk III Midget Body Parts Service List Spridgets 3
rjc157 For Sale tr6 body parts Triumph Classifieds 0
D Body Parts Austin Healey 1
maxwedge5281 aluminum body parts Austin Healey 15
W Likely need a few Bugeye inner body panel parts Spridgets 0
madhouse RF Fender and Lower Cowel Body Parts needed Austin Healey 10
J Best body panel parts Austin Healey 8
AHS TR2/3/3A Which parts are NOT body color? Triumph 9
TR6oldtimer TR4/4A TR4, parts car not body Triumph 6
CinneaghTR Post-War Other Free Herald Body Parts in NC Triumph 12
B Mechanical & body service parts manual BJ7/BJ8 Austin Healey 2
H Body Parts Triumph 5
deadair If you need body parts Triumph 0
RickB 79 [guess] Midget body& parts free in Issaquah WA Spridgets 2
Jarhead Body parts MG 5
BOBBYR Moss body panels and frame parts Austin Healey 3
JPSmit LBC body parts Other British Cars 0
Taz Body parts for a 1500 Spridgets 0
H Need some body parts Austin Healey 9
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
