TR2/3/3A back seat bracket
sp53
I noticed something I had not been aware of in that there was some kind of bracket used to hold the top part of the back seat in place; the bracket looks simple like perhaps a J shaped hook to fastens to the seat and then to the tub and is covered up by the trim. Does anyone have a picture of an original?
STeve 1958
I've had two TR3A's and neither had a bracket there. That's not to say that there wasn't one, but the seat back stays in place without it.
S
sp53
Yeh I have had a few tr3s myself and none of them had a bracket. I did have the seat keep sliding out of those slots one on and drilled a couple of holes on the very lip of the back side of the seat and pulled the seat in from the trunk and wired it to those C shaped brackets that the seat wedges into.
I have no life, so finding new things on a tr3 interest me; how exciting. Anyways, when I noticed how the tub had a recess where the back seat goes and there was a corresponding hole in the seat, I thought I had figured something new and astonishing out. Perhaps I could make them and become rich.
The way I see it there was some engineering for something there and maybe the early cars had something.
David posted a bracket for the steering column that I had never seen before-- plus I kinda thought before there should be something there to hold that side. Moreover, the radiator over flow tube bracket was unknown to me until a couple years ago, so there is hope for more unknown parts on a tr3 kind like "exhibition unknown" on TV.
TRopic6
Steve.
That's where the hardtop brackets go (aka "Bridge Piece"). Here is a page from the workshop manual showing how to fit the hardtop. Apparently after TS6824 the body was stamped for the brackets. I dug out my old rear panel - no holes that might match those on the rear deck; looks like yours is the same.
S
sp53
I hear Tropic6 I have those holes also, and I have a hard top hooked up with all the fittings on another car. This indent is dead center and has a recess for something to slide back into right at area around the gas cap on the sheet metal of the tub. Is that a 3/16 hole I see in the center at the top back of your back seat panel or a speck of dirt?
TRopic6
OK - I see what you are talking about with the recess and small hole. I think my back panel does have a center hole but will confirm tomorrow.
S
sp53
My guess is a bracket that looks a lot like the other back seat brackets on the tub but was screwed onto the seat first then when the seat was slide back a screw was put into the tub to hold the seat from sliding forward. Or maybe kinda like the ones on the bottom of the seat; something simple. I have had the seat slid forward before and wired them back. Don E would have probably known.
S
sp53
I got the back seat in anyway. The hole that is by that tentative bracket I suggest is also the center for the trim.
S
sp53
I struggled with how to do it; I cut some foam but decided to glue right onto the medal. It is far from perfect and I pulled it up and glued it 3 times. After getting sooo much glue on the seam and moving to 3M 99 for better sticking, I was able to turn the hard nylon seam down--- then laying the glued up mess flat parts of the nylon seam down the edge of the arch.
It might have been better to take some very fine cotton batting and put some on either side of the seam, just a little; it was something like that originally . Moreover, this really nice retiring upholster named Char made me some softer white piping to go around the trim.
HealeyRick Need BJ7 Seat Belt Bracket Location Austin Healey 4
roofman TR6 Seat bracket question TR6 Triumph 8
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
C Seat Slide Bearings Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
mrv8q TR2/3/3A TR3A TRF vinyl seat reupholstery kit Triumph 7
J TR4/4A TR4A seat retaining clip Triumph 5
R BJ7 Back Seat-Rest Austin Healey 1
A TR2/3/3A Seat position Triumph 2
jlaird Wanted One Bugeye seat Spridgets Classified 0
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
J TR4/4A Seat install, Spring clip Triumph 0
