TR6 Fuel float
sundown
sundown
Thanks Poolboy, Are you still in the business of rebuilding the stromberg 175cds. If so what are you charging for a rebuild on the set. Thanks
poolboy
Yes, I am still rebuilding ZS carbs for fellow TR6/250 owners. Thanks for asking.
Currently it's 270 USD/pair which includes parts, labor and return shipping to a US address within 10 days.
Here's my contact address:
kencorsaw "at" aol.com
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
R TR4/4A Fuel pouring out of float bowl Triumph 3
R TR4/4A Fuel pouring out of float bowl Triumph 10
P Fuel Float to tank bolts [machine screw] size?????? Spridgets 1
britlover Rear SU float not seating -- fuel overflow Austin Healey 24
M Fuel sender unit float leaks Triumph 8
AUSMHLY Float bowl fuel height BJ8 Austin Healey 4
K Stuck float in Su fuel bowl.restoring carbs. Triumph 3
AUSMHLY fuel sending unit float position Austin Healey 16
R bBJ-7 testing fuel tank float Austin Healey 2
Gerdo Fuel Float? Where to buy? Triumph 8
J Fuel Overflow at back float valve Spridgets 2
B Fuel Sending Unit Float Triumph 14
bighly Fuel Sending Unit Leakey Float Replacement Austin Healey 9
H Fuel Tank Sending Unit Float Austin Healey 11
T TR4/4A TR4A Fuel Starvation problem: Dry float bowls Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
