Float bowl fuel height BJ8
AUSMHLY
Bronze
I've been reading up on how to tune the carbs. Different carbs have different hinged lever settings. If the settings are off, the floats will be off.
What effect does having the fuel at different levels in the float bowl affect the running/performance?
For the HD8 carbs I believe the hinged levers should be adjusted to 7/16".
But if the levers are set wrong, then the floats will be off. How would the following affect the car.
1. different float heights between the two bowls.
2. same height in both bowls, but floats rest at half way instead of near the top (where it should be if correctly set).
There are no stupid questions, right?
Cheers,
Curious George
Keoke
:savewave:
7/16" is correct for HD8 Carbs
NO FURTHER COMMENT OPN THIS TOPIC.--KEOKE---- :laugh:
It affects the level of the fuel in the well (jet) and to a certain degree, you compensate for that while you adjust the mixture (by raising/lowering the jet).
It gets more complecated than that (especially with Webers, and the transition from the idle circuit to the main circuit) but if the level in an SU float bowl is "close enough" to the recommended level, they can be tuned.
Roger, check out the Moss tech videos. They have one on setting the floats. (Find it on there web-sight along with 104 other great videos). They used a drill bit and explained what to look for and what position the float should be in and where exactly to put the drill bit.
Patrick67BJ8
As I recall, the float lever may need tweaking a bit depending upon whether or not you used the original needle & seats or the Grose seats.
Patrick
R TR4/4A Fuel pouring out of float bowl Triumph 3
R TR4/4A Fuel pouring out of float bowl Triumph 10
K Stuck float in Su fuel bowl.restoring carbs. Triumph 3
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Lin Post in float bowl came loose Austin Healey 6
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
J BJ8 Float bowl vent pipes Austin Healey 11
Martinld123 Push button on top of new H6 carbs float bowl from Moss Austin Healey 3
lbc_newbie Float bowl overflow Spridgets 7
K SU float bowl....measuring the height? Triumph 13
dklawson Hs4 Float Bowl Failure Spridgets 11
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
MadRiver ZS Float Bowl Plug Leak Triumph 8
P Leak on H-1 Float Bowl Spridgets 5
A carb float bowl gasket Triumph 7
E TR2/3/3A TR3 carb float bowl Triumph 5
JPSmit Hi there - SU float bowl needed Triumph 0
Monark192 Leaking Float Bowl Question Spridgets 25
MGTF1250Dave SU H6 Carb, Float Bowl Mounting Bolt Triumph 2
K TR2/3/3A TR3 SU float bowl grommets. Triumph 1
Nunyas SU HS float bowl location... MG 13
Y Float Bowl "O" ring dimensions for Zenith Strom Ca Lotus 1
A TR4/4A TR4 HS6 carb float bowl lid orientation Triumph 2
jtb55 Float bowl over flow Austin Healey 6
S Carb Float Levers Austin Healey 6
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
GeorgeC HS 2 float adjustment Spridgets 5
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
J TR6 End Float Triumph 5
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
T TR6 Carb. Float Chamber Fix Triumph 5
2 General TR SU float settings Triumph 3
jfarris TR2/3/3A Metal washers for SU H6 float bowls Triumph 1
S TR2/3/3A understanding the float and needle set up better Triumph 6
sundown TR6 Fuel float Triumph 3
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
Healey Nut Carb float Austin Healey 16
dklawson GT6 Float Height, 150CD [Early CD, Not Later CDSE or CD2SE] Triumph 7
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
R TR2/3/3A Establishing distributor shaft end float Triumph 4
S BJ8 Float Level Austin Healey 37
M TR2/3/3A SU H Type Carberator Float Lever Adjustment Triumph 10
Lin HD6 1-1/2" SU Front [L/H] Float Chamber Austin Healey 1
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
R Front wheel bearing - end float Austin Healey 40
steveg Carb float setting tool Austin Healey 11
KVH General Tech Distributor Gear End Float Triumph 6
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
