TR2/3/3A Wiper Cable Lube
JFS
Bronze
What lube should be used for the windshield wiper inner cable? Sil Glide brake pin lube has been suggested. Any others?
Mickey Richaud
White lithium grease works well. Anything's better than what was used back in the day and has solidified by now!
TomMull
I had the motor off mine while working on the brake cylinders so I cleaned and greased it. It was a solid lump with impressions where the moving parts went but it worked well before and after the new grease went in. I did not remove, clean or grease the cable but the old solidified grease didn't seem to matter.
Grease is like wine in that there are lots of brands and types available but they will all get you buzzed; and don't use too much of it.
Tom
CJD
I've always felt that grease, either white lithium or chasis grease is the best lubricant. That said, any grease will harden and become useless in a few years. So, I use grease for parts I plan to use and maintain well. If I plan to let it sit and appreciate with minimum maintenance...I use the spray graphite Tom mentioned. The graphite has no shelf life...but don't use it on aluminum parts.
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
T TR4/4A Removing wiper motor - inner cable Triumph 4
A TR2/3/3A TR-3A wiper lubricant [tubes and cable] Triumph 1
Tinkerman TR2/3/3A TR3A wiper cable question????? Triumph 10
hondo402000 TR6 TR6 wiper cable and greasing it Triumph 11
JPSmit wiper cable Spridgets 2
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
R TR2/3/3A TR3 Wiper motor Triumph 10
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
R TR2/3/3A Wiper Arms Triumph 8
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
R TR2/3/3A Windshield Wiper System Triumph 2
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
M TR6 Wiper washer knob Triumph 5
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
P Wiper direction Austin Healey 9
R GT6 Wiper Motor problem and time capsule Triumph 4
N TR2/3/3A Wiper motor armature Triumph 11
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
J TR2/3/3A Wiper Motor bracket Triumph 5
JPSmit Question - wiper switch and signal switch ends Spridgets 4
T TR5/TR250 TR250 wiper switch and motor Triumph 1
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
sparkydave Wiper switch repair Spridgets 5
F TR2/3/3A Beware eBay wiper blade and arm sales Triumph 6
