TR2/3/3A Slight clunk in the rear assembly somewhere.
sp53
Slight clunk in the rear assembly somewhere. I thought this clunk might be a U joint or a bad spline on one of the wirer wheels, but after I started looking around under the car I think it might be too much play in the rear flange at the U joint. The U joint seems fine and might have 7K on it. So, How much play/slop should there be before the drive line goes into motion. There seems to about ÂĽ to 3/8 of an inch before the drive line is firmly engaged plus that could be the clunk.
CJD
Steve...you're back! I thought the Chinese might keep you to extract Triumph secrets!
1/4 to 3/8 sounds pretty typical for the pinion gear play. The real key for a differential is if it makes noise, especially passing 30mph, 60, 90, and 120mph's. If that flange were loose it would make a lot of racket. U-joints will give you a high frequency vibration when they go out... and they are normally noticeable when you grab hold of the drive shaft (car in neutral) and rock it back and forth.
Hopefully it's just something simple, like the brake assemblies dragging slightly and rocking back and forth with the drum motion.
TR3driver
Great Pumpkin - R.I.P
I'm confused; are you saying the flange moves relative to the driveshaft? That's a serious problem.
But if it's just backlash inside the differential (pinion turns but wheels don't move), that's no big deal at all. I'd say 1/4" is about normal, but my last TR3A was worn until it was more like 1/2 turn! Most likely wear in the brass thrust washers (the "yellow metal" bits), possibly caused by using the 'wrong' oil (before I got the car).
S
sp53
If I grab the drive line and twist, there is about 3/8 or so play before anything happens. I can rock it back and forth or in this case side to side; it does not go in and out. So I guess that is what John is saying—the ring and the pinion have movement.
I have rebuilt everything I can think of except the differential. Over the years, I would just find a used one and replace the unit. An old buddy of mine would saw that, do not bother trying to fix one of those because they are never the same and difficult to get correct, but that was many years ago.
Yes I am back from South East Asia. I made friends with some Cambodian people when they left after the Kamer Rouge or Chinses Communist genocide back in 1977, and have been there many times since. I am here to say the Chinses are back in large numbers and have actual purchase one whole beach town and discourage English spoken there. The Chinese are taking over Cambodia and Vietnam by legal means with the money we give them. Heck look around everything is made in China. The Chinese that relocate there can have more than one child plus I heard they cannot go back to China. I could go on all day about this—it might get ugly over there again.
steve
K TR2/3/3A Slight surging at Idle? Triumph 11
71TR6 TR2/3/3A Slight tweak to Martx-5's dogleg covering method Triumph 9
HighAltitudeTR3 TR2/3/3A I have a tick, or maybe a slight tock... valves? Springs? What? Triumph 11
Jim_Gruber Dilema - Take it back apart or not - Slight and I mean really slight LF Wobble Spridgets 3
Martinld123 A slight hesitation stumble at speed Austin Healey 13
busybrit MGB Slight starter motor noise MG 5
JPSmit Slight Vauxhall Latest - and a question Other British Cars 57
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
JPSmit Slight rant Other British Cars 9
V 1275 slight miss, what's the cause??? Spridgets 20
Anthony_S TR2/3/3A TR3a slight shake at 60-65 mph Triumph 8
M Slight bind in front brakes Spridgets 7
bigjones Slight timing problem Spridgets 3
longbridgehealey very slight miss Austin Healey 3
T GT6 slight vibration in GT6, with power Triumph 4
bigjones HS4 - 1500 - slight problem Spridgets 24
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
bigjones Slight wheel alignment problem Triumph 9
JPSmit slight rant - solenoid Spridgets 3
J Spitfire Slight intermitant 78 Spitfire Triumph 14
kodanja Slight changes Triumph 16
Woodie hs2's slight hesitation under load Spridgets 40
P Slight engine hesitation Spridgets 7
P Slight loss of brake assist until pumped once Triumph 4
Sherlock Suggestion for "slight" name change Rover / Land Rover 1
S slight clicking/tapping noise after a head rebuild Spridgets 4
Basil Slight problem with rear hubs [EType] Jaguar 7
T Rear/Differential "Clunk" Austin Healey 2
W MGB There"s a clunk in my B. MG 12
JPSmit Honey, did you hear that clunk? Other British Cars 0
Jim_Gruber Clunk in the rear when shifting Spridgets 26
J MGB Project car done; front end clunk noise while braking MG 4
jfarris TR2/3/3A Clunk when engaging clutch Triumph 1
tahoe healey clunk on braking. Austin Healey 4
T TR6 Passenger side TR6 rear clunk? Triumph 9
TR4A_IRS Driveline Clunk Diagnosis Triumph 28
tahoe healey Clunk noise Austin Healey 32
rlich8 TR4/4A TR4A Clunk - What's the "go to"? Triumph 4
B Cure for the Datsun trans "clunk"! Spridgets 0
Jim_Gruber LF Suspension Clunk identified Spridgets 4
bighealeysource Found my clunk coming from the rear ! Austin Healey 9
bigjones Clunk ..clunk Spridgets 33
R what's that clunk? Spridgets 42
Jer rear suspension rattle/squeak/clunk remedy... Spridgets 20
RickB CLUNK taking off with spirit Spridgets 34
R Driveline Clunk!!! Triumph 1
jbowlby Backing up I heard a "clunk" Spridgets 17
J Can anyone help with my MK2 axle clunk? Jaguar 7
kodanja I hear a clunk? Triumph 7
M Clunk in the rear Austin Healey 32
