That's a clunk when the car is started and a clunk when turned off. Sounds like it is generally coming from the steering wheel area.
I thought it might be that the dreaded thrust washers had lost interest but a quick check indicates they are OK (push clutch pedal in, insert crow bar between lower pulley and tubular cross memeber and try to push pulley backward - any sign of movement is sadness all round).
Those who have followed my misery know I've just replaced the starter motor - that R&R took 2 days so I really don't want to go through that again so I thought I'd ask. The replacement (from my 1275) was a bit stiff but a spray with some penetrating fluid freed it up nicely (the spring-loaded whuzzit that goes in and out).
Any thoughts would be appreciated.
Cheers
Cheers
