TR2/3/3A Rear axle hub dis-assembly
Philthytoo
In researching seperating the hubs on a TR3 rear axle, I read of potentially warped hubs from badly set-up press work, and astonishing amounts of pressure needed to get them apart. I read an older post where a tool was made that the threads on the flange around the axle end, then used a bolt to press the axle through. After hanging the axle/spindle/hub assemblies vertically and soaking them with penetrating oil for a couple weeks, I set one up in my low-budget 12 ton press, cranked on the pressure, and got nowhere. The older post included part numbers from McMaster-Carr, so I ordered the stuff: Monster nut to thread onto the flange, smaller nut to weld onto the big one, and a 5" bolt to do the pressing. I drilled holes in a 4 foot piece of angle iron, used lug nuts to hold it over 2 of the wheel studs, clamped the axle to a bench, and with a friend and 2 three foot long wrenches pulling together the axles came out without a sound.
A big Thank You to the folks here! Never would have thought to try this method.
One note: An impact socket to fit the bolt (2-1/8") is Really Expensive. I welded a smaller nut (1-1/2") to the bolt head, and used a socket I already had. That gave us 2 places to wrench from.
CJD
Nice...definitely a better way than using the press alone. I've collected all the parts to build a puller, but haven't gotten around to it yet...
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
W Rear Axle Hub Seal Austin Healey 8
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
Lin Rear Axle Hub Nuts Austin Healey 3
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
K TR2/3/3A Rear axle hub removal? Triumph 8
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
B Spitfire advice on rear axle/hub Triumph 4
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
glemon Bent Rear Hub/Axle Triumph 2
dklawson Spitfire Spitfire - Rear Hub Bearing & Axle Assembly Steps? Triumph 17
64rocksprite Rear axle hub - bearings Spridgets 8
G TR6 TR6 Rear Axle and Hub - saga continues Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
drooartz Bugeye jack points to remove rear axle Spridgets 18
R BJ7 Rear Axle Maintenance Austin Healey 5
A Rear Axle Oil Seal Austin Healey 4
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
B How often should you change the rear rear axle oil Austin Healey 9
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
T TR2/3/3A Rear Axle Vent Triumph 12
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
B TR2/3/3A Checking oil in rear axle Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
catfood BN1 Rear Axle drain plug. Austin Healey 7
Don_R TR2/3/3A Rear Axle bearings Triumph 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
