TR2/3/3A banjo bolts to seal up on the early SUs
sp53
I am having trouble getting those banjo bolts to seal up on the early SUs. Are those little gaskets made poorly or any suggestions would help. They are pretty straight forward, but I cannot get them to seal.
steve
S
sp53
I always forget about him, but yeh I bet it is those seals. I hate to tighten them up like that and they are still leaking. Glad to hear there is another solution because something was going break. I thought about maybe block sanding the one surface, but they are new and should seal up easy.
steve
TR3driver
Great Pumpkin - R.I.P
Might be worth checking that they are thick enough. Try assembling just finger tight, without the fiber washers, and measure how much clearance there is. If two washers don't stack up thicker than that, use 3 of them.
TuffTR250
I got some gasket material from Advance Auto parts and cut it in the shape of the fiber gasket and put one on each side of the fiber gasket along with some Hylomar sealant and that helped seal it up.
G HD8 Carb Banjo Bolts Austin Healey 2
B Brake fluid leak - banjo bolts Spridgets 13
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
J Carburetor Banjo Seals Austin Healey 11
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
PAUL161 MGB Early B Banjo Rear Gears MG 2
R TR2/3/3A Lockeed rear brake banjo fittings. Triumph 7
NutmegCT T-Series Carb banjo washer leaks? MG 9
Mickey Richaud General MG MG Banjo MG 3
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
Rob Glasgow Carb Banjo Gaskets Austin Healey 8
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
Don_R one for banjo Spotted 0
PAUL161 MGB Early Banjo Rear Question MG 8
vette Banjo Fittings Austin Healey 11
B General TR Unusual banjo pieces for brakes? Triumph 3
mgedit TR2/3/3A Banjo Connectors TR3 Brakes Triumph 4
Johnny Fuel pump banjo bolt 101 Austin Healey 3
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 2
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 7
Johnny SU fuel pump banjo fittings stripped out Austin Healey 19
S banjo type fuel lines--vacuum advance Triumph 0
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
J Help with oil pipe banjo bolt. Spridgets 11
DNK Banjo Bolt Triumph 2
6 Rear brake banjo bolt/61 Bugeye Spridgets 3
aeronca65t Spitfire-Banjo Ben Spotted 0
M_Pied_Lourd Banjo Made Me Do It........ Triumph 11
DNK Intake Banjo Triumph 47
D Modified Banjo Steering Wheel???? Triumph 8
PAUL161 MGB Wanted-Early MGB Banjo Rear MG 15
Lynn Kirkpatrick Cracks in '68 banjo steering wheel MG 9
Gordon_Dedrick TR2/3/3A TR3 Banjo Fuel Fittings Triumph 1
angelfj1 TR2/3/3A TR3A - Fuel Tank Banjo Bolt Triumph 6
S Minor "Banjo" wheel in a Mini? British Motor Corp 0
angelfj1 HAPPY BIRTHDAY BANJO Triumph 7
M MGB MGB Banjo Rear Hub re and re wire wheels MG 0
drooartz Banjo bolt and washers Spridgets 6
Tinkerman TR 3 A banjo bolt and fuel tank vent. Triumph 1
AUSMHLY Healey banjo steering wheel modified to 15" Austin Healey 8
T Photo for Banjo Triumph 18
T Watch Banjo fly-Live Triumph 11
C Banjo rear, new hub help. MG 4
B Banjo Fitting - Oil Pressure Line Triumph 6
AUSMHLY Banjo vent Drain pipe Austin Healey 16
vping Banjo vs. Tubed rears MG 11
tony barnhill Banjo 3rd Member MG 5
S TR2/3/3A Flexible banjo fuel lines on early tr3s Triumph 0
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
