zenith-stromberg carbs
lotuslover
On my Elan what is the correct fuel pump pressure? I can't seem to get them to pull fuel up thru the needle and seat.
Platinum
Three to five PSI. Are you still using the mechanical pump?
Platinum
Look for ~ethanol~ damage in the Strommies. The stuff will plug jets with green garbage and stop fuel flow after only a month or so.
L
lotuslover
Been there done that with the green slime. I just cleaned the Z-S and reset the float level at minimum spec.
Platinum
Good diaphragms? Best to check 'em by holding them in front of a light source and stretching them a bit all the way around their circumference to check for pinholes.
As long as the fuel is getting into the reservoir and vacuum pulls the pistons up (dependent on diaphragms with no leaks), the thing should light off. I will assume you have disconnected the supply hose at the carbs and checked to actually see fuel being pumped out.
Some Q&A curiosities:
175 CD's?
Has it run with this same pump ahead of this issue?
Could the floats be somehow binding against the sides of the float bowl?
Could some vacuum take-off at the intake runner or carb bodies (vacuum port to the dizzy or brake boosters) have deteriorated so vacuum is diminished at the throats of the carbs?
Trying to think of any other things which might affect fuel delivery...
L
lotuslover
It is a new pump, I'll check all the vacuum outlets, most of those have been plugged by the PO. It does run when primed. Thanks!
64Elan
I respectfully disagree with you. The correct pressure should be approx. 2.5 psi. If using an electric fuel pump use one that can supply a higher pressure and install a fuel pressure regulator after the pump that can be adjusted to 2.5 psi. That's what I've done on mY elan it runs so smooth at that pressure. I believe the pressure for Webers or Strombergs will be the same.
Platinum
An SU diaphragm pump, or a Facet "low pressure" one will supply enough volume without pushing the float needles off their seats and no need for another device in the mix. I feed the set of dual Webers in the Spider and the Elan with SU or Carter low-pressure pumps. Never had a flooding or delivery issue.
Unless you are willing to go for a Holley regulator, a location to mount it and all that jazz, I say stay with the low pressure pumps. They've all worked for me on my personal vehicles whether running SU's, Webers or Strommies. I've put them on dozens of clients' cars as well.
What I ~have~ seen is those cheezy dial-a pressure regulators come apart to spew fuel all over the engine bay, one resulting in a toasty Alfa!
L
lotuslover
I have one of those pressure regulators on the car, haven't had any problems yet. I wonder how accurate the settings are? Never bothered to check it.
Lotuswins
Hi Jody,
I have ZS's on my TCS Europa, and have the dial regulator too, made by a reputable firm, not the cheapie type, but never had a problem with it. I checked pressure from it upon installation, and it matched the dial. But check it just in case.
I had trouble at one time with Grose Jets sticking closed as I didn't wash them in acetone before installing them. As a second check, pull the diaphrams/pistons out and see if you can see the gas near the top of the needle jet. As Dr Entropy said, check the diaphrams, and I am running 2.5 psi on my ZS's, works great.
I had trouble starting my TC a while ago, and had to pull the starter to ensure it was cranking fast enough. Once I overhauled that, it seemed to start easier. FWIW, I also installed a starting circuit (choke) on the rear carb, and a CD ignition which also helped it to start when cold.
I hope this helps, Jerry
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Zenith stromberg carbs Jaguar 3
martx-5 Zenith Stromberg Carbs Triumph 4
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
77_MG_Midget Zenith Stromberg Carbs Spridgets 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
bfitz Zenith Stromberg O ring question Other British Cars 8
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
R Zenith Stromberg CD 175 float replacements? Triumph 3
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
M zenith stromberg? Triumph 1
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175cd Triumph 0
M zenith stromberg 175 cd. Triumph 7
R Zenith Stromberg Running Lean - Up-date MG 1
R Zenith Stromberg Running Lean MG 7
I Zenith stromberg metering needle removal help Triumph 9
I zenith stromberg float brass plug removal help Triumph 14
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
J Zenith Stromberg question MG 4
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
H Zenith Stromberg CD 175 Too rich Triumph 7
Bret Yet another Zenith Stromberg replacement choice MG 6
S Zenith Stromberg Mixture Adjuster Restoration & Tools 13
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
bluemiata90 zenith stromberg cold start adjustment Triumph 5
John75 Intro and Zenith Stromberg question Triumph 8
A Zenith-Stromberg tuning & parts MG 20
R Zenith Stromberg basic adjustment Triumph 1
7 Zenith Stromberg Question??? Triumph 6
7 Rebuilding Zenith Stromberg MG 6
Bret Zenith Stromberg 175CD vs. SU HIF44? MG 13
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
Celtic 77 MGB Tinny Zenith air regulator MG 0
P Zenith Carburetor Triumph 2
P MGB Zenith water choke gasket needed MG 4
P MGB Zenith 175 cd carb damper oil MG 2
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
sparkydave Zenith auto choke coming loose Spridgets 2
C TR6 Zenith Strombers won't start when warm. Triumph 2
sparkydave Zenith auto choke coming loose Spridgets 3
A Zenith 175 CD's Triumph 19
A Zenith 175CD carbs Triumph 9
CZ_Dave Zenith Carb MG 13
B Question- Spridget & MGB Zenith flanges? Spridgets 2
Ofcalipka Zenith single carb problems MG 62
