wrinkle paint
lefty
Hello there...
I need to paint my 67 dashboard, but I cannot find the right color.
Does any one knows any brands or anything else.
I gave it for a proper paint job but it is to glossy. The original was a nice mat one.
Thanx
tony barnhill
Great Pumpkin - R.I.P
Moss has the correct crinkle paint
Platinum
I've just done mine with PlastiCoat "Wrinkle Paint" #217 black. It is a very good match in my opinion.
I stripped the whole thing, put a coat of epoxy primer on it, then applied the wrinkle finish according to the instructions. The BEST method I found to get it to "go off" properly (uniformly) was to set it in direct sunlight after the last coat.
I've tried to emulate the original finish a number of times unsuccessfully, I believe the primer coat had a lot to do with the success.
dklawson
Wrinkle finish paint can be a little tricky. Try it on a test piece of metal first. Be sure to follow the manufacturer's instructions. In small print some paints mention that the wrinkle won't appear until at least 10-12 hours after the second coat is applied. Be patient. If after that time the paint hasn't wrinkled, I've found a light 3rd coat followed by placing the part in a warm area (like the sunlight mentioned above) does the trick. Again... practice on scrap metal first to learn how the paint behaves.
vping
Bronze
Does anyone know if this would match the crinkle on the wiper motor for a TD?
R6MGS
I used a tremclad wrinkle paint on my TC wiper motor...worked like a charm, almost perfect match.
BlueRidge1
Lefty, A trick I've used in the past with wrinkle paint on small parts is place them in an oven and warm them up (not real hot) I did my harley cyl. jugs about 150-175 degrees then sprayed them. They dry and crinkle almost instantly and crinkle evenly. You may want to practice on a non valuable part. (May want to wait till the wife ain't around
also) Disclaimer, I am not responsible for any trouble from wife ,parts destroyed houses burnt etc.
All kidding aside it did work very well. Bob
Platinum
Yes, Bob. "funny" smells from the oven while there's a turkey in there later can raise questions and eyebrows... I always blame it on loose cat fur. Pre-heating bits works great.
Problem with the MG facia is it's a bit too long to fit inna kitchen oven.
jlaird
Might warm it up good with a hair dryer?
Bruce74B
Kim De B did an nice essay with pictures a couple of years ago when she did her dash. I think she used the hair dryer with great looking results.
Deleted member 3577
[ QUOTE ]
[/ QUOTE ] /ubbthreads/images/graemlins/lol.gif
Most of the places that do powder coating also have a process for crinkle painting (They call it ridge paint)
I haven't had luck w/ the Moss rattle can stuff....
Not because it wasn't possible to perfect your technique.
After all my trouble, It ended up having a low abrasion resistance.
Platinum
If I find anyone abrading my dashboard, they're dogfood.
Deleted member 3577
Its easier to repair & repaint a fender than to take a dash out and fix it.
I used that Moss stuff and scratched the paint horribly just trying to reassemble it. /ubbthreads/images/graemlins/cryin.gif
In fact you might say it resembled used dog food. /ubbthreads/images/graemlins/grin.gif
dklawson
I tried painting hot/warm parts when I first worked with wrinkle finish paint and my results were typically partially wrinkled paint in a sea of otherwise thick satin colored paint.
Repeating what I said earlier, try the paint first on a piece of scrap and carefully follow the manufacturer's instructions. The part and environment do need to be warm but don't start adding lots of heat until you've at least tried the manufacturer's recommendations. Pay careful attention to when to apply the second coat and how long they say it takes before you should expect to see wrinkles.
And all those comments about wrinkle finish being easy to scratch or destroy... they're correct. Factory applied wrinkle finish paint will be much tougher than anything out of a can. I found it necessary to allow about a week of curing/drying at room temperature before you should even think of handling parts. The stuff just doesn't stick well and wants to "tear" when disturbed.
Deleted member 3577
I STRONGLY recommend that you have a powder coating company do your dash.
First check for examples of their work. A guy near me does old pay phones for someone and they look fantastic.
(If you terrify your passengers like I do, You might want something that is fingernail proof)
Platinum
[ QUOTE ]
...(If you terrify your passengers like I do, You might want something that is fingernail proof)
[/ QUOTE ]
A point I hadn't considered, that.
Hmmm.
Nunyas
attach a set of door handles to the dash for the obligatory "Oh Sh.." handles.... /ubbthreads/images/graemlins/jester.gif
Deleted member 3577
My little brother has claw marks all over the inside of his Vixen.......Some of them are mine.
Platinum
"Crisis of Confidence"?
Deleted member 3577
He doesn't really like driving with a passenger..........
Not because of the weight.........It restricts his visibility when counter-steering around a lefthander. /ubbthreads/images/graemlins/grin.gif
R TR2/3/3A Crinkle/Wrinkle Finish Triumph 4
S TR2/3/3A black wrinkle or black smooth,tr3 Triumph 5
G A new wrinkle in postings Triumph 6
mcguijo TR2/3/3A wrinkle finish on TR3 Triumph 2
J Wrinkle krinkle and zinc primer Triumph 2
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
TomMull Paint over galvanized parts? Restoration & Tools 8
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
J 1960 Bugeye Paint Codes Austin Healey 1
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
J Flaking Paint Inside Differential Austin Healey 6
C Under boot and under bonnet paint? Austin Healey 7
T TR2/3/3A Chassis paint color Triumph 10
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
vette MGB Paint Code MG 8
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
