WOW! You think you have an oil leak!
10musketeer
The other day I noticed oil all over my pants. I had recently checked the oil on the dipstick and passed it off as dumb carelessness. Next day- new pants, more oil. After looking around I noticed the seat belt is soaked in oil. End result is I have a leak that is so bad it's somehow getting through the tunnel and onto the floor board under the drivers seat where the seat belt is wicking up the oil! I need to find out where it's coming from and how it's getting into the car and try to clean the oil out of the belt. Guess I have my winter project now. :frown:
jlaird
Maybe, just maybe your oil pump cover is leaking.
tony barnhill
Great Pumpkin - R.I.P
But, I'd toss that seat belt & buy a new one.
bugimike
Is the oil "clean" or "dirty"? If it is clean-looking, it could be leaking from the tranny, which would put it right near the seatbelt mounting point!! That sound like a lot of oil to be making it that far back from the engine!! Before you trash the seat belts, try soaking/cleaning them with Marine Spray 9 (IMHO the BEST degreaser around...and also a disinfectant!!). I would also use the same product for de-greasing the rest of the mess, including inside the tunnel!
Sarastro
Are you sure that the line to the oil pressure gauge isn't cracked?
If oil is getting into the passenger compartment any other way, I'd expect it be all over the firewall or transmission tunnel and easy to see.
10musketeer
10musketeer
It's clean, so I think it's the gearbox. I'm assuming its leaking on the tray and "working" its way to the floor via the emergency brake (?) or some other opening. I noticed when I last filled the tranny with 20w50 the PO had used gear oil. I think the thinner oil is getting by the seals.
healeyboz
stick your hand up inside the tranny tunnel from the back. That should let you know.
My first thought was the oil gauge as well. But probably not that far back.
jlaird
There is only a quart in the tranny. What is the level? Is it down, with that much oil it should be.
JPSmit
Maybe now would be a good time to suggest a RHD conversion
10musketeer
10musketeer
HA! That got me thinking. I checked the right side floor to make sure there is no problem there, but it's dry. Oil probably flows to the driver side because I'm usually alone so the car leans left. :smile: At least the interior smells more british car-like!
jlaird
Wonder if it is comming out the oil filler hole.
asoupley
10musketeer said:
...I noticed when I last filled the tranny with 20w50 the PO had used gear oil. I think the thinner oil is getting by the seals.
what damage could gear oil do to one of these transmissions? (don't worry, I have not done this!)
jlaird
Little slideing things do not slide correctly mostly. The stuff is too thick.
JPSmit
as you describe it, I'm supporting the cracked oil gauge/ sender pipe as the culprit. There is only three transmission places the oil could be coming from.
1. the back - in which case it would be thrown back onto the car underbody.
2. the front - in which case it would drip but not likely be thrown or
3. the shift hole itself - I've never heard of oil being thrown out of this as nothing is spinning right there.
Likewise, it would have to be thrown very hard to penetrate the emergency brake and soak the interior to that level. And, oil doesn't wick uphill on steel.
On the other hand, the oil in the oil gauge pipe is there at 20-60 lb per square inch and a little crack could force it out at a decent pressure. you also wouldn't necessarily see it if, for instance, it were at the junction of the pipe and the gauge. Here I could imagine a scenario of the oil running along the inner back lip of the dash and dripping on the carpet on the tranny hump - the cloth carpet would wick the oil.
when I was trying to get Ms. Triss started, I discovered I had not tightened the oil gauge nut enough and there was a pretty impressive drip just from that.
at any rate, I'd be looking there first - good Luck!
bugimike
Since it is clean oil, I still think it is probably tranny oil! If it was from the guage, I'm thinking you would have much more oil further forward (at least in line with the dash) than where the seat belts attach. Make sure you didn't over-fill the tranny as it will leak from the rear seal when over-filled. Also, if you park the car with the nose up-hill it could leak from the rear seal! You can look into the tunnel from above at the shifter and from under the car at the rear to see if there is a lot of oil in the tranny tunnel. It can build up in there as it is a pretty good catch-tray. Oil spilled while filling the tranny and from leaks can build up in there and about the only place it will escape is at the hand-brake!!! If there is a lot of oil in there a good way to sop it up is with an "oil-sorb"...these are "diaper-like" pads found at a marine supply. They are great in that they absorb oil like a sponge!!!
HAN8L1965
Maybe the seal at the rear of the transmission where the spline eneters is failing that would put oil directly in that location. It is probably seeping in around the ER Brake lever as that is closer to the tunnel floor.
Mark
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
Basil Pre-War 1937 MG SA - Wow! MG 4
S General TR 1949 Triumph Roadster on eBay.....wow Triumph 18
TomMull Wow British Motor Corp 6
TR4nut General TR All I can say is wow Triumph 12
Basil Wow - EType breaks auction record! Jaguar 0
K Wow, Check out this Healey Project Austin Healey 16
tinman58 General TR Wow what a deal!! Triumph 3
Tosh TR6 WOW Triumph 5
RickB Just put headrest speakers in - wow! Spridgets 8
glemon Wow Other British Cars 5
Tr3aguy TR2/3/3A 47K TR3....wow Triumph 5
Jer Wow ! - Beauty is in the eye of the beholder... Spridgets 14
George Zeck Legroom Up-date [WOW !] ....... Spridgets 3
AngliaGT Wow! Lots of Old Cars Spotted Today Spotted 0
RickB wow in Olympia WA craigslist Spridgets 7
Randy Forbes Wow, nice cover Dougie... Austin Healey 15
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
W WOW!!! Spridgets 23
Sarastro Wow! MG 0
HerronScott Wow Triumph 6
PAUL161 The Chevy 789! Wow! Other Cars 5
R WOW It Must be Spring!! TVR 2
B wow, what a deal? Triumph 12
AngliaGT Wow! 11 New Nortons Found British Motorbikes 3
Rob Glasgow Wow, now that feels different... Austin Healey 20
regularman Wow, its close Spridgets 25
PAUL161 Bugatti Veyron Road Test. WOW! Other Cars 3
walshja WOW Spridgets 7
T Finally used my pressure bleeder - WOW! Triumph 1
M Wow - I Unexpectedly Wound Up With an Alpine Sunbeam (Rootes) 6
G WOW..I used to have one of those! Triumph 20
T It's a small thing, but WOW. Triumph 25
Tabcon TR4/4A Automotive Review - 1964 TR4...WOW! Triumph 5
AweMan WOW, Enlightened Triumph 5
1965_MGB Rear Axle Removal.... Wow MG 10
Russ Austin "WOW" 1954 SWALLOW DORETTI on Ebay Triumph 19
regularman Wow, what a heat wave Spridgets 16
Tinkerman Wedge Wow!!!! Saw a Wedge Today in Crossville!!!!!! Triumph 4
jlaird Wow, Spridgets 18
msoylemez Wow. What A Weekend. Spridgets 9
W WOW!!! Spridgets 8
B WOW! WHAT I SAW YESTERDAY!! Spridgets 2
G TR6 A friend just sold his check-book TR6.....wow Triumph 21
sparkydave Everything's working right! Wow! Spridgets 3
YankeeTR Wow...nice '56 on ebay Triumph 37
john_j WOW!!! V8 Healey!! Austin Healey 21
Sparkie Wow, a Costin on EBay! Other British Cars 20
YankeeTR Wow..This car has 'shot pinged' rods...huh? Triumph 17
TR4nut Wow, someone has some really BAD rear bearings.. Triumph 6
