I have been installing a new wiring harness in my '60 Sprite as part of the almost completed restoration. You may recall that I posted an earlier query regarding the installation. I received some good advice. As a result, I went back through the harness, checked every connection. I discovered a couple of connections that were not right, as well as a defective flasher. Based on my friend Charlie's advice about making sure that all grounds were well connected, I rechecked the grounds and found some problems. I then decided to rework the grounds. I installed two bolts through the firewall, making sure that there was lots of shiny metal in contact with the bolts. I replaced all the one wire bulb holders with two wire holders and took the resulting ground wires back to one of the bolts. I then extended all the other ground wires to the other bolt. All of the ground wires have crimped and soldered connectors protected with heat shrink tubing on the end which is connected to the grounded bolts.
Ok, all is well..Right? Nope! The lights, turn signals, wipers all work, but, with the lights on, when I engage the dip switch, the inline 10 amp fuse blows...I am sure the dip switch is connected correctly, But something's not right. Any thoughts on what to check/do now? FYI the tach is converted to electric and there is a Flamethrower distributor, so these are connected into the system. I believe these are connected correctly, but...
Oh, and I did ground the white with black wire from the harness in the engine bay since the distributor comes with its' own wires.
One other thing..the wiring chart shows a white wire running from the combination ignition/lighting switch to the cigar lighter. The other side of the cigar lighter has a red/white wire running to the panel light switch. I do not have a cigar lighter. Should I run a wire from the panel light switch directly to the combo switch?
Many thanks in advance for any thoughts/ideas!!
