TR4/4A Wiring harness female bullet connectors
Rut
Strange question...I'm rebuilding 2 67 TR4a wiring harnesses and one came with the standard black rubber female connectors, single and double and the other came with grey silicone rubber connectors. I don't know if the grey ones are earlier or later or just different, but my 1960 Bugeye came with black as did the 1973 Midget and 1970 MGB. Thoughts?
Thanks, Rut
TR3driver
Great Pumpkin - R.I.P
There's a comment in Piggott to the effect that different suppliers were used for the harness, more or less at random. My guess is that you're seeing the effects of that.
Geo Hahn
My 64 TR4 with its original harness is 100% grey connectors. Not just the bullet connectors but also the covers over the Lucars (female spade connects). I don't know that they are silicone - I would have just called them 'rubber'.
Was a short lived thing I think though I was ale to get a cheap hacked harness to have some spares.
I have also encountered that bullet connector in white - no idea who used those.
Rut
Rut
Randall,
Thanks, I missed that. That said I did notice that the wrapping and the tape used on the bifurcations were different as well as some of the branching points along the main harness. I've cleaned everything really well to reveal the true color of the wires and soldered new wires of the same color and gauge to the mouse eaten ends...the soldered wires were covered in shrink wrap tubing and will be wrapped with the proper outer wrap material once everything is tested.
Thanks, Rut
Rut
Rut
George,
I may be wrong on my terminology, but I also have the grey Lucar connectors and they appear to be more of a plastic than silicone...also have the clear spade covers.
Thanks, Rut
Geo Hahn
I do not know the material but yes, there are some clear ones on a couple of sub-harnesses (brake lights in this pic):
Vila
On my 62 TR4 all the female bullet connectors have black rubber covers and all the spade connectors have clear boots.
Not sure if the clear spade connector boots were originally a clear golden/brown-ish color or whether it is because they are 54 years old.
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
S Wiring Harness Replacement Spridgets 1
B TR4/4A Wiring Harness Triumph 6
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
nichola TR6 Question on new wiring harness Triumph 6
R TR2/3/3A Replace wiring harness in steering column Triumph 61
Ripper01 For Sale- TR6 Wiring Harness Triumph Classifieds 0
R TR2/3/3A Install new wiring harness in steering column Triumph 16
ckeithjordan TR2/3/3A Wiring Harness Question[s] Triumph 10
nichola TR6 Victoria British wiring harness for TR6 Triumph 6
C For Sale MGA wiring harness MG Classifieds 3
C MGA Wiring harness question MG 7
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
R TR2/3/3A Installing wiring harness in steering column Triumph 59
BoyRacer How to clean a cloth wiring harness Austin Healey 14
S TR2/3/3A installing the wiring harness Triumph 8
A Spitfire BMCNE -Tech Session Custom Wiring Harness Creation -Links to Album Triumph 2
W TR2/3/3A New wiring harness Triumph 8
T TR2/3/3A Wiring harness Triumph 3
D new wiring harness Austin Healey 15
D 62 tri-carb wiring harness Austin Healey 10
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
SherpaPilot Wiring Harness for XJ6 Jaguar 1
tr3guy TR2/3/3A New Wiring Harness Triumph 7
MisterB How to spin engine sans wiring harness? Austin Healey 3
Marvin Gruber BJ8 wiring harness install Austin Healey 6
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Rut 73 Midget wiring harness Spridgets 0
K TR2/3/3A Wiring harness "wire gauge" sizes? Triumph 20
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
charleyf TR6 Wiring harness/ dash bulbs Triumph 2
K TR2/3/3A Wiring Harness Triumph 9
Got_All_4 TR2/3/3A TR3 A wiring harness Triumph 17
B TR6 Reverse light wiring harness routing Triumph 4
J Protecting new wiring harness under car section-Use clear shrink tubing? Austin Healey 4
mt10flyer TR2/3/3A TR3 wiring harness Triumph 7
Rut Wanted, Bugeye wiring harness Spridgets 0
Griz Rear Wiring Harness Question Austin Healey 6
R TR2/3/3A TR3A Overdrive Wiring Harness Installation Triumph 19
Rut Bugeye wiring harness Spridgets 2
mt10flyer TR2/3/3A Winter Project-Wiring Harness Triumph 4
R New wiring harness Austin Healey 8
MikeAH100M Need New Wiring Harness BN2 Austin Healey 2
P General Tech new wiring harness woes MG 6
D MGB Wiring Harness Installation MG 3
D New custom Bugeye wiring harness Spridgets 39
vette New Wiring Harness Austin Healey 6
