New Wiring Harness
vette
I have to make a decision about the new wiring going into my car and I would like to ask for your opinions. My car is not completely stock and most changes are for the interest of long term durability, enhanced options (sterio & fog lights) and ease of maintenance. So hence I am modifying the electrical system as well. I will have an alternator, and a negative ground system along with twin fuel pumps and a throwover switch for them. But here is my latest consideration:
Many years ago i eliminated the Overdrive throttle switch and have been engaging my OD directly off of the dash toggle switch. It is kind of fun to drop it down right at the flip of the switch and also shift it up the same way. No messing with the throttle switch adjustments anymore.
I also have had a desire to have a better fuse box with many circuits having their own fuse and room for more accessories. Today I started to install the new wiring harness and then had to continplate where to put the new fuse box. I thought about under the dash near the drivers side but then felt that there was no convenient place there for it. Then i realized that I'm not using the throttle switch, so why would I need to keep the O.D. relay as well. On my BJ7 the fuse box, OD relay and throttle switch all reside on the engine side firewall, drivers side, approx directly above the throttle/carb linkage. If I eliminated the old fuse box, the relay, and the throttle switch I would have enough room on the firewall to put in a decent sized fuse box with the more modern spade blade fuses. Without the throttle sw, and relay, the white/purple wire from the OD dash switch can go directly to the white green wire of the transmission 3rd & 4th gear shifter switch. Does that make any sense, and do you see any downside to this. I think some might believe that I am cannibalizing the car. But I havn't had the OD relay or throttle sw in the circuit for years anyway, why keep them hanging on the firewall and it will eliminate one or two items that could fail during a road trip. Also I wouldn't be cutting up the harness, originality could easily be restored with the addition of the removed components. Am I forgetting something, I think it will work. What you say? Dave C.
I think you need the O/D relay for the same reason the O/D relay was installed in the first place: to use a small current from the panel switch to switch a larger current through the relay to the solenoid. In my experience the panel switches are somewhat fragile to begin with and removing the relay would only make them more so. I've replaced a couple panel switches, but the relay on my BJ8 lasted about 150K miles and when it started to fail--on the road in Canada--I opened it up and filed the points and it held up for several thousand more miles before I replaced it. I don't know the rating of the switch but if it could handle the load Austin wouldn't have 'wasted' the pound or two it cost to install a relay. The fact your switch has lasted surprises me--how many miles a year do you drive?
I rather like the throttle switch, too. You can throw the switch when you're coasting, then when you get on the accelerator you get an automatic 'kick down' gear. Very high tech. Once set properly they don't seem to be much problem, either; IIRC I opened mine up once and cleaned up the points and adjusted per the manual and it's been flawless for 170K+ miles.
Patrick67BJ8
Go to John Simms website for Fuse Blocks, www.healey6.com . Charlie Hart on Calif. has made Fuse Blocks for 7 fuses. He has just sent me one for BJ8's which is new and I'll be testing. BJ7 and BJ8's are very different wiring for the Fuse Block area. Green wire hookup's are opposite sides.
steveg
Charlie's email: hartcg@msn.com
I'm using one if his non-BJ8 versions.
5
57_BN4
Dave- as you have identified, the OD relay functions as a latch (with the throttle switch) to protect the OD clutch from disengagement under hard engine braking and also as a relay to protect the dash switch from the 30-odd amp current that the solenoid draws at pull-in. There are two windings in the OD solenoid, a high current one to pull it in and a low current one to hold it in plus a set of contacts to open the high current coil once it is pulled in.
If you remove the OD relay then your dash switch might fail at some time but I'd reckon if you use a more modern switch you'd get a fair amount of use out of it between fails. The high current is only for a few milliseconds then it goes to about one amp.
Andy.
vette
vette
Andy, Bob and All,
I am very sorry that my most recent post to this thread was materially in error. So I have deleted it. Just after I posted it and read Andy's response, I did some more digging which is what I should have done to begin with. I found some of my older material and relized my memory of the circuit was totally wrong. Bob is very much correct in gaurding me against removing the OD relay. I realized that I had removed the throttle switch but the relay was still in operation. I think! that is probably why my dash switch has not given out on me after 7 or more years of about 2000 miles a year. Thanks again everyone for your advice & help. Dave C.
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
S Wiring Harness Replacement Spridgets 1
B TR4/4A Wiring Harness Triumph 6
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
nichola TR6 Question on new wiring harness Triumph 6
R TR2/3/3A Replace wiring harness in steering column Triumph 61
Ripper01 For Sale- TR6 Wiring Harness Triumph Classifieds 0
R TR2/3/3A Install new wiring harness in steering column Triumph 16
ckeithjordan TR2/3/3A Wiring Harness Question[s] Triumph 10
nichola TR6 Victoria British wiring harness for TR6 Triumph 6
C For Sale MGA wiring harness MG Classifieds 3
C MGA Wiring harness question MG 7
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
R TR2/3/3A Installing wiring harness in steering column Triumph 59
BoyRacer How to clean a cloth wiring harness Austin Healey 14
S TR2/3/3A installing the wiring harness Triumph 8
A Spitfire BMCNE -Tech Session Custom Wiring Harness Creation -Links to Album Triumph 2
W TR2/3/3A New wiring harness Triumph 8
T TR2/3/3A Wiring harness Triumph 3
D new wiring harness Austin Healey 15
D 62 tri-carb wiring harness Austin Healey 10
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
SherpaPilot Wiring Harness for XJ6 Jaguar 1
tr3guy TR2/3/3A New Wiring Harness Triumph 7
MisterB How to spin engine sans wiring harness? Austin Healey 3
Rut TR4/4A Wiring harness female bullet connectors Triumph 6
Marvin Gruber BJ8 wiring harness install Austin Healey 6
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Rut 73 Midget wiring harness Spridgets 0
K TR2/3/3A Wiring harness "wire gauge" sizes? Triumph 20
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
charleyf TR6 Wiring harness/ dash bulbs Triumph 2
K TR2/3/3A Wiring Harness Triumph 9
Got_All_4 TR2/3/3A TR3 A wiring harness Triumph 17
B TR6 Reverse light wiring harness routing Triumph 4
J Protecting new wiring harness under car section-Use clear shrink tubing? Austin Healey 4
mt10flyer TR2/3/3A TR3 wiring harness Triumph 7
Rut Wanted, Bugeye wiring harness Spridgets 0
Griz Rear Wiring Harness Question Austin Healey 6
R TR2/3/3A TR3A Overdrive Wiring Harness Installation Triumph 19
Rut Bugeye wiring harness Spridgets 2
mt10flyer TR2/3/3A Winter Project-Wiring Harness Triumph 4
R New wiring harness Austin Healey 8
MikeAH100M Need New Wiring Harness BN2 Austin Healey 2
P General Tech new wiring harness woes MG 6
D MGB Wiring Harness Installation MG 3
D New custom Bugeye wiring harness Spridgets 39
