Got_All_4
I heard some talk on here before about hard to pull TR3 choke cables. I am now experiencing the same thing after fixing a zero jet travel when setting the choke. It just showed up after putting the car away last winter and wanting to get it out last week end. I discovered that the pivoting holes on the jet levers were worn to a 1/4" hole and that slop was being taking up by the travel of the choke cable. It was one of those get r done projects because I wanted to drive it so I took the jet levers off and brazed the now worn 1/4" pivoting holes and re drilled them to 7/32". Lubed everything up and now the jets drop nicely but only after taking 2 men and a boy to pull it out. I should add that the first 1" comes out fine. It's the rest of the travel to get the jets to drop that gets so hard to pull. Before I order new jet levers could there be something else I'm doing wrong?
