TR2/3/3A Whitworth Threads (as on the bolt)
TR3MT
Bronze
Hello TR3 Aficionados--I have read all the threads (discussions) about Whitworth threads (fasteners) which are really interesting and on point but not quite what I am looking for. I have made a complete restoration of my TR3A (TS50260L) and over the years have always replaced a lost or missing nut, bolt or cap screw with a UNF (SAE) part that seemed to fit. The only exception I found was the mixture adjusting nut on the SU carburetor. I am just wondering if anyone has ever seen an inventory of where Whitworth threads were used. I used to think all post WWII cars exported from England to the US used UNF or UNC (SAE) hardware. After reading the threads it appears there were several exceptions.
Thanks for your interest,
TR3MT
NeilRogers
I'm not aware of any Whitworth fasteners on Triumphs. It's a different story with an MG.
sp53
Brass starter nut, some of the heater nuts and bolts on top, I think, gauge knurled nuts on back of the case, and some of the SU car linkage.
CJD
In general, large bolts are SAE, while small screws are whitworth. So, 1/4" and larger are SAE. Smaller machine screws will be Whitworth. Then, a lot of repro parts will muddle the mix by throwing in an occasional metric, or SAE. Carbs are always odd...
jfarris
My filler plugs on the rear lever shocks are an odd size? Nothing fits!
Sarastro
I've found BA and BSF screws and threads used here and there in the carburetors and distributor. I suspect that's what you mean by Whitworth. I've never found real Whitworth threads on anything in my TR4A. BA and BSF a 55 degree thread angle, which I think is the same as Whitworth, and use the same set of head sizes as Whitworth, but the heads are one size smaller--e.g., a 3/8" BSF bolt uses the same head as a Whitworth 5/16. The thread pitches are not the same.
If real Whitworth fasteners are used anywhere on the TRs, I'd be interested to know what and where.
JimLaney Whitworth Threads or Just Nuts! Spridgets 5
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
D Whitworth on 59 Sprite. Spridgets 11
JPSmit Whitworth Question Restoration & Tools 23
jfarris TR2/3/3A Whitworth fill plug for lever shocks Triumph 2
MikeAH100M Whitworth Source Austin Healey 8
Basil SOLD!! Set of Whitworth Sockets for sale Other British Classifieds 1
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
LarryK Whitworth tools Restoration & Tools 5
bowiderberg Spitfire Whitworth on a Spitfire 1500? Triumph 8
timbn2 Whitworth / BSW tap and die question??? Austin Healey 25
M Addendum to searchin for Whitworth screws Jaguar 2
M Source needed for Whitworth-BSF screws,etc. Restoration & Tools 2
C Need info on Whitworth hardware Restoration & Tools 3
timbn2 whitworth / king dick tools... where to get.? Austin Healey 4
G I need a quick tutorial on Whitworth wrenches MG 6
B Quality of various Whitworth spanners Restoration & Tools 9
EinsteinsDad Grade markings on British Whitworth Fasteners Restoration & Tools 4
KVH TR4/4A TR4/4A Gas Line Whitworth Questions Triumph 0
Britishtools More in depth Whitworth Thread Information Restoration & Tools 3
Britishtools Mr Joseph Whitworth: Inventor and Engineer Restoration & Tools 7
B Whitworth - where?!? Austin Healey 7
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B Damaged threads in the gas tank Austin Healey 7
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
S Stripped Threads Austin Healey 10
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
JimLaney Organizing threads into book? FORUM Navigation Questions 10
vette Threads for the Water Temp Sender Austin Healey 6
R BJ7 spark plug threads Austin Healey 17
Mickey Richaud General MG Two More Threads! MG 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
Basil Admin Note Use Prefixes to filter threads you read MG 4
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
KVH TR4/4A Wrong Threads on New Fuel Pump? Triumph 13
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 8
S TR2/3/3A Spark plug threads Triumph 10
PatGalvin TR2/3/3A Heater Spacer Threads are a mystery Triumph 4
M stripped threads on master cyl Spridgets 12
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 1
Jer chasing spark plug threads on head? Spridgets 8
A TR2/3/3A TR-3A Windshiedl Tenex Peg Set Threads Triumph 2
T TR2/3/3A What size and threads for corner finisher on TR3A windshield Triumph 3
S Where are the threads from 11/7 - 11/17? Austin Healey 2
KVH What happened to all the threads between "today" and November 6? Triumph 6
TulsaFred Harmonic balancer threads Spridgets 2
J Stripped threads engine block Triumph 7
L Removing chrome from threads Spridgets 16
M Bajo bolt and rocker pedestal threads.. Austin Healey 6
