Grade markings on British Whitworth Fasteners
EinsteinsDad
I'm tring to identify the hardness/grade of new and old Whitworth BSF nuts and bolts. I'd like to use the equivilent of grade 8 fasteners on the suspention as I restore my 53' MGTD. Most of the old and new bolt heads I have are marked with an "R" on the head. I believe this indicates the approximate equivilant of SAE grade 5. Can anyone please give me more information about makings, hardness, coatings etc., of British Whitworth fasteners.
Thanks
Britishtools
I found this interesting article regarding this topic.
Quote:
"For British bolts the grade for high tensile is the letter "R" (45 Tons per sq in), and for American it is the letter "S" (50 Tons per sq in). The latter two equate in strength to 8.8 grade in metric."
Britishtools
All BSF or BSW hardware is graded 700-850, which is a Grade "R"
Min - Max Hardness Brinell is 201-255
All UNC or UNF hardware is graded 775-925, which is a grade "S"
Min - Max Hardness Brinell is 223-277
Apperently there are no deviations from this grading for BSF or BSW hardware. This measurements equate a grade 8 in metric.
Rut Grade 9 bolts Spridgets 6
Rut MGB Grade 9 bolts MG 4
Rut TR4/4A Grade 9 bolts Triumph 6
sim 58 sprite suspension up grade or not Spridgets 25
KVH Grade 8 Bolts Triumph 7
MadRiver Multi-grade oil in gearbox? Austin Healey 2
I Suggestions for drilling a hole in a grade 8 bolt? Triumph 24
I Internet source for grade 8 bolts? Triumph 12
T Sourcing Grade 8 bolts..... Triumph 23
19_again grade 8 nuts on ?grade studs MG 14
I rear axle to differential flange bolt grade? Triumph 8
Tinkerman Grade 5 or Grade 8? Triumph 13
hondo402000 alternator up grade and smoking dash Triumph 19
W What grade of gas/petrol ?? MG 17
A TR6 Up-grade to 1/2" lug bolt, which ones??[tr6] Triumph 7
M TR4/4A OE tr2,tr3,tr4 aircleaner up-grade!! Triumph 4
hondo402000 TR6 alternator up grade for 71 TR6, what works Triumph 8
V New Grade 12.9 Socket Head Bolts Triumph 2
I Best bolt grade for Triumphs Triumph 20
R what grade oil Austin Healey 2
T Where to buy Factory Grade Paint? Triumph 6
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
HealeyRick Inspection Markings Austin Healey 5
K TR4/4A TR4A vinyl top boot cover factory markings??? Triumph 0
K TR2/3/3A SU needle identification markings? H6's Triumph 3
C TR5/TR250 Tr250 suspension inspection markings Triumph 0
Dougal BN1 rear hub markings Austin Healey 3
6 cam markings Triumph 2
MGTF1250Dave Rear Axle Markings MG 5
M Phillips Head Screw Source with Correct Markings Austin Healey 8
K Speedometer markings: OD and not OD that is the ? Triumph 8
T TR2/3/3A TR3 flywheel markings Triumph 5
Stinger TR4/4A TR4A Under Hood Grease Pencil Markings Triumph 14
MGTF1250Dave TR2/3/3A TR3 Temperature Gauge Face Markings Triumph 3
scoutll Piston markings translation please Spridgets 0
RickB Markings on B210 5speed? Spridgets 4
M TR2/3/3A ???? TR3 Factory Markings ???? Triumph 15
davidk TR6 TR-6 Engine Markings Triumph 1
A BN7 trunk floor markings Austin Healey 10
SportsSixter Tyres in the US & Can - White markings / logos Triumph 3
H 3 ltr engine BN4 to early BJ8 - dipstick markings Austin Healey 8
S Flywheel Markings Austin Healey 2
Steve Factory markings ?? MG 14
Rick_Thompson TR2/3/3A Sanford Fl All British Car Show, April 6th Triumph 0
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
tr6nitjulius General TR British Car Mechanic SoCal Triumph 0
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
P TR2/3/3A British High Torque starter Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
