Re: alternator up grade??? which one
You would be correct. I have a cd player, amplifier(sp), upgraded halogen head lamps, and halogen fog lamps, electric fuel pump lots of relays, MDS spark unit. driving around now the amp meter is always pegged on Charging, and last night after a long drive I noticed the lights getting dim and the cd player kept going off so I figured either the battery is going or the alternator is not putting out enought amps to run everything and all the electricals are runnning off the battery too. To answer your question I am sure you can add up all the draws and pick an alternator to suit but 55-60 amps should work for me?
