TR4/4A TR4/4A Gas Line Whitworth Questions
KVH
The gas line fittings at the tank and the fuel pump are Whitworth, close to 1/2 20 American fine, or approximately that.
But I can't find those Whitworth fittings anywhere. In addition, the 5/16 British steel line is smaller than American 5/16. The wall is thinner. All in all, the line measures about .003 thinner, and the Whitworth line nut is actually about .005 wider on the outside diameter than an American 1/2 20 fine.
It appears, however, that I can just substitute with a 1/2 20 fine line nut, 5/16 American steel line, and a 5/16 ferrel for the compression fitting. I'm told the seal is all in the ferrel and that the other differences (i.e., between the 1/2 20 fine and the Whitworth counterpart) are immaterial.
Is that right? Help, please. I want to get it back on the road.
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
BobbyD TR6 TR4 & TR6 Gas Tanks Triumph 6
KVH TR4/4A TR4 Gas Tank Triumph 3
M TR4/4A TR4 Optimal Compression - 91 Octane Pump Gas Triumph 13
K TR4/4A Exterior of TR4 gas tank...inside OK Triumph 3
R TR5/TR250 Tr4, 4A and 250 gas cap position? Triumph 6
S TR4/4A late tr3 and tr4 gas caps Triumph 4
T TR4/4A Gas tank leak on TR4 Triumph 5
J TR4/4A TR4 gas and temp gauges don't work Triumph 7
M TR4/4A TR4 Gas Cap Triumph 6
KVH TR4/4A Removing the Gas Tank TR4 Triumph 6
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
