TR5/TR250 Tr4, 4A and 250 gas cap position?
Richard_Brown
Ok I have owned a tr250 and 2 tr4a's and the gas caps all opened from the back, I keep seeing photos where the cap is rotated so you open it from the side ( so the lip flips open to the side of the car rather than toward the front of the car).
what is the correct position?
DNK
Actually , they should be diagonal, IIRC, so the boot can be opened while getting fuel
RJS
The correct position is that it opens from the drivers side, be it right hand or left hand drive
Bob
John_Mc
Mine is on diagonal. Don't know if that was PO arbitrary positioning or intentional. Seems to make sense that you'd want access to the boot while fueling.
HerronScott
I don't have a great picture of it but the Triumph accessories list for the TR4A seems to show it opening from the driver's side in the shot showing the luggage rack as does the TR4A owner's manual (although that one's opening from the right-hand side since presumably it's a picture of a right-hand drive car).
Scott
DanB
I have mine with the latch to the rear so the cap swings toward the cockpit. I think I did that so it would help block any splashes that may occur, plus I just like the way it looks better.
Dan B
DNK TR4/4A TR4 & 5 owners and 250 Triumph 19
CinneaghTR TR5/TR250 TR4/RA/250 Rear Bumper Installation Triumph 3
TR4A_IRS TR5/TR250 Have you added 3 point belts to your TR4/5/250/6? Triumph 10
Alan_Myers TR5/TR250 What's a roll bar worth? [TR4/250/6] Triumph 8
V TR5/TR250 difference on surrey tops tr4 vs tr4A/250 Triumph 2
K TR5/TR250 tr4 to 250.... Triumph 15
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
