Whitworth Question
Roger
Bronze
The crankshaft thread was much beloved by Austin. It appeared on Austin Seven crankshaft and half-shafts long before the A-type.
I have read that it was originally an Admiralty specification.
JPSmit
JPSmit
OK sorry I asked this wrong - if you go to the (kijiji) ad it is selling wrenches and sockets - I thought the different bolt head sizes were metric/ Imperial (American) and Whitworth.
Aren't the head dimensions of BSF and BSW threads the same as any other imperial bolt size? IE a 7/16 bolt uses a 7/16 wrench regardless of thread size?
Roger
Bronze
American wrench sizes are measured Across Flats. A 1/4 in bolt has a 7/16 head, typically, a 5/16 has a 1/2 inch.
BS wrenches (spanners) are marked with the thread size, and the heads are not the same as SAE sizes.
timbn2 Whitworth / BSW tap and die question??? Austin Healey 25
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
D Whitworth on 59 Sprite. Spridgets 11
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
jfarris TR2/3/3A Whitworth fill plug for lever shocks Triumph 2
MikeAH100M Whitworth Source Austin Healey 8
Basil SOLD!! Set of Whitworth Sockets for sale Other British Classifieds 1
JimLaney Whitworth Threads or Just Nuts! Spridgets 5
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
LarryK Whitworth tools Restoration & Tools 5
bowiderberg Spitfire Whitworth on a Spitfire 1500? Triumph 8
M Addendum to searchin for Whitworth screws Jaguar 2
M Source needed for Whitworth-BSF screws,etc. Restoration & Tools 2
C Need info on Whitworth hardware Restoration & Tools 3
timbn2 whitworth / king dick tools... where to get.? Austin Healey 4
G I need a quick tutorial on Whitworth wrenches MG 6
B Quality of various Whitworth spanners Restoration & Tools 9
EinsteinsDad Grade markings on British Whitworth Fasteners Restoration & Tools 4
KVH TR4/4A TR4/4A Gas Line Whitworth Questions Triumph 0
Britishtools More in depth Whitworth Thread Information Restoration & Tools 3
Britishtools Mr Joseph Whitworth: Inventor and Engineer Restoration & Tools 7
B Whitworth - where?!? Austin Healey 7
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
