Wheel bearings
R
RonR
Neither Moss or Victoria British sell Timken bearings for a 3000.
Moss stocks FAG inners and SKS outers.
Victoria British stocks GHB inners and PTC outers,
Tom's Import Toys sells WB kits including bearings, seal and grease. Tom is a Moss distributor and gives 15% off Moss parts--I don't know if that applies to the kit or not--but I bought a couple and thought the price was more than reasonable. IIRC the bearings were SKS. NFI.
RAC68
Back in the 1980s, I went to a local bearing shop and provided the original bearings and seals for front and rear wheels along with the differential. They took all and provided me with an exact match for all which has been installed ever since. Although I can't tell you the manufacturer of the bearings or seals, the price of each unit was 1/3 less then the prices being charged by Moss.
If I ever need a bearing and/or seals, my first move will be to find a local bearing shop and ask them to find a proper match. My confidence in their knowledge and experience relating to bearings is much higher then I have for Moss or most of the parts houses dealing with Healey parts.
My thoughts,
Ray(64BJ8P1)
vette
Ray has related what I consider to be the right approach. Local bearing shops don't exist because they sell junk. They usually exist because they service alot of industry besides the local auto industry. They may sell different brands and they may discribe one brand as cheaper or lesser than another but they will usually tell you the differences. If you want the best just tell them you want the best. Bearing are very specific and their tolerances are very specific. If you have existing bearings and you take them to a local bearing shop and tell them you want quality replacements, they surely can provide.
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
Donald1107 TR2/3/3A Wheel bearings Triumph 8
algot1901 HELP with wheel bearings Other British Cars 1
Z 3000 Front Wheel Bearings Austin Healey 3
FlyingCat Spitfire Wheel Bearings Triumph 3
R General Tech Wheel bearings Triumph 3
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
N Wheel bearings?? Spridgets 4
N Front wheel bearings?? Spridgets 8
pan Front wheel bearings [BN1] Austin Healey 6
M BN1 front wheel bearings Austin Healey 5
C TR2/3/3A Front wheel bearings Triumph 8
Jim_Gruber New Wheel Bearings Question Spridgets 9
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
steveg Shimmed rear wheel bearings Austin Healey 13
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
sparkydave Groaning noise - wheel bearings? Spridgets 5
G MGB Front Wheel Bearings MG 2
P Bugeye Front Wheel Bearings? Spridgets 1
Morris Front wheel bearings Spridgets 9
N Front Wheel Bearings?? Spridgets 4
Rut Front wheel bearings [again] Spridgets 12
R TR 3b front wheel bearings Triumph 5
D Front wheel bearings Austin Healey 48
P front wheel bearings for 79 midget? Spridgets 4
Jer re-packing front wheel bearings Spridgets 3
tomshobby front wheel bearings Spridgets 13
Tabcon Rear wheel bearings- GET OUT! Triumph 7
N TR6 How to check TR6 front wheel bearings Triumph 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Atrus INeed opinions/experience - front wheel bearings Spridgets 7
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
Jim_Gruber Wheel Bearings and Thrust Label Spridgets 6
W Front Wheel Bearings Austin Healey 3
vping 1991 Ford Ranger Wheel Bearings help needed Other Cars 0
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
RickB T-Series 70 BGT - Brakes, wheel bearings, etc MG 9
T Front Wheel Bearings Triumph 26
T TR6 tr6 front wheel bearings Triumph 15
philman Saab 9000 Wheel Bearings Other Cars 6
M Wheel Bearings Triumph 6
M Wheel bearings again Triumph 10
MGFever Upgraded Front Wheel bearings Spridgets 8
T "How To" front wheel bearings Triumph 18
Luke_Healey Fun with wheel bearings... Spridgets 14
J Rear Wheel Bearings Austin Healey 3
eejay56 Spitfire Spitfire wheel bearings Triumph 9
H Bugeye Wheel Bearings - Question Spridgets 7
prb51 Front wheel bearings Triumph 13
