Vertical vs. Cross-flow radiator
WALTER
I have the choice of the two styles of radiators to put in the '62' Sprite I'm reviving. Is either one significantly better than the other. I'm not overly concerned about stock and it will have a 1275 engine in it.
Thanks,
Walter
Bugeye58
Walter, the early 1275 cars used the down flow radiator, and I never had any cooling problems with them. The crossflow requires a different shroud, and you will have to run the crossover tube that bolts to the steering rack, as well as the separate expansion tank. The 1275 had two different water outlets, depending on which radiator was used. The crossflow setup is also marginally lighter.
If you do go with a downflow type, living in Santa Rosa, you may want to look into having a thicker core installed.
Do you have the '62 radiator to work with?
Jeff
WALTER
WALTER
Yes Jeff, I have two of the '62' style. I figured I could take them both to a radiator shop to get checked out. If they didn't like one they could go to the next. Have them set it up for the new shallower caps while it's there.
Thanks for the help.
Walter
Bugeye58
Walter, just for informational purposes, I've got a '65 Sprite, with an extremely built 1098 in it, that lives just east of Lake Berryessa. It still has the downflow radiator in it. I've never had a cooling problem, and you know how hot it gets in the valley.
Jeff
WALTER
WALTER
That's encouraging. Thanks.
Walter
Tullamore
I have a Midget with the downflow and a sprite with the crossflow. The Midget NEVER overheats and the Sprite ALWAYS overheats. The sprite even has an electric fan on it. The radiator may need to be recored but in my experience the downflow works best.
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
S TR2/3/3A vertical links Triumph 8
banjojambo Triumph tr3 vertical link wobble Triumph 2
V TR2/3/3A Vertical link check Triumph 2
S TR2/3/3A Vertical link Triumph 3
S TR2/3/3A How bad is this? Vertical link Triumph 12
J TR2/3/3A L/S Vertical Link Resistance Triumph 17
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
mcmillal TR4/4A Broken Vertical Link Triumph 17
J TR2/3/3A Need a TR3 vertical link Triumph 1
T TR2/3/3A TR3B vertical link Triumph 13
T Help on ball joint - vertical link fit Triumph 20
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
T Vertical link questions Triumph 4
Bremer Help with vertical link assessment Triumph 6
C Distributor shaft vertical play? Triumph 4
tinman58 Vertical Links Triumph 5
B Vertical link question Triumph 1
HEALEYJAG 100 vertical fin from apron panel set Austin Healey 8
M Removing Stub Axle from Vertical link Triumph 22
G trunion/vertical link seal Triumph 5
GB1 Vertical Oil Cooler Lines Racing 6
svtmikey Front Vertical links Triumph 3
S MGB Transmission cross member re-install MG 14
Healey Nut Cross Rod Correct Length Austin Healey 14
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
F TR2/3/3A Throttle linkage cross rod Triumph 4
G 100/6 Radiator cross member Austin Healey 6
G TR2/3/3A Cross reference for hardware Triumph 8
R Wanted WTB Spitfire race/auto cross car Triumph Classifieds 1
J TR6 TR6 Cross Tube Differences? Triumph 6
J front cross member height from bottom to floor on BJ8 Austin Healey 5
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
S Difficulty removing end rods and cross rods Austin Healey 11
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
S TR2/3/3A cross tube back on Triumph 3
J E Brake cross rods Other British Cars 6
PatGalvin TR2/3/3A Engine Cross Tube Challenges Triumph 6
RJS TR4/4A Clutch Slave mount into cross shaft Triumph 3
oxford steering cross rod Austin Healey 13
stuntflyr Solo cross country Healey frame transport. Austin Healey 17
Boggsy64 MGB Front Cross member pads MG 4
G 100-S in 1000 K cross country race Austin Healey 6
H gear reduction starter cross reference Austin Healey 12
C 1500 gt pre cross flow Other British Cars 4
andrea Austin Healey 100/6 cross flow heater pipeclips Austin Healey 3
M TR4/4A TR4A muffler hanger to cross member attachment Triumph 13
