Vertical link question
Bob_D
Member
Greetings,
Rebuilt the left front suspension first ('58 TR3A)-- vertical link threads were shiny and clean, looking like it had just been manufactured yesterday. Slapped on a new lover trunon and put it all back together. Now we are doing the right side, and the vertical link threads are pitted and no matter how much I try to clean the threads, it still has a dark tint to it -- not nice and shiny like the left. When I spin a new trunion, hold the assembly upright and wiggle the trunion there is a little side to side movement.Is this a reasonable way to judge wear? Unfortunately, I don't recall any wiggle on the other side, but I wasn't concerned and it's too late to compare. Any words of wisdom? I'm attaching a photo, but I'm not sure you can see the problem. Finally, if I do need a new vertical link, does anyone know if there is a quality difference between the vendors for this important part? Thanks
PS I really appreaciate all the helpful advice I've received in my short time as a member (and will need in the future)
TR6oldtimer
Your method to determine wear is appropriate. That said, the problem you are witnessing could be the trunon itself. Some of them were not well made.
When I was in this position on my six, I ordered a new vertical link from Moss ($225) because they have a liberal return policy (and rapid refund) which allowed me to test fit the new trunon. In my case, it was the vertical link that was worn, if not I would have returned it. Oh, by the way, I purchased my trunons from TRF.
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
banjojambo Triumph tr3 vertical link wobble Triumph 2
V TR2/3/3A Vertical link check Triumph 2
S TR2/3/3A Vertical link Triumph 3
S TR2/3/3A How bad is this? Vertical link Triumph 12
J TR2/3/3A L/S Vertical Link Resistance Triumph 17
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
mcmillal TR4/4A Broken Vertical Link Triumph 17
J TR2/3/3A Need a TR3 vertical link Triumph 1
T TR2/3/3A TR3B vertical link Triumph 13
T Help on ball joint - vertical link fit Triumph 20
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
T Vertical link questions Triumph 4
Bremer Help with vertical link assessment Triumph 6
M Removing Stub Axle from Vertical link Triumph 22
G trunion/vertical link seal Triumph 5
S TR2/3/3A vertical links Triumph 8
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
C Distributor shaft vertical play? Triumph 4
tinman58 Vertical Links Triumph 5
HEALEYJAG 100 vertical fin from apron panel set Austin Healey 8
GB1 Vertical Oil Cooler Lines Racing 6
svtmikey Front Vertical links Triumph 3
WALTER Vertical vs. Cross-flow radiator Spridgets 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
D MGB Rear Suspension Damper Link Arm MG 2
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
N Watts Link??? Spridgets 2
H broken sway bar link - again Austin Healey 8
T TR2/3/3A tr3a verticle link removel question Triumph 11
G BJ-7 Rear Shock Link Austin Healey 2
B Support bracket for the rear suspension damper link Austin Healey 5
D TR4/4A stubborn lever shock link Triumph 2
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
N Top link offset bushings?? Spridgets 6
T TR5/TR250 250 Sway Bar Link Triumph 0
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
DornTRoriginal TR2/3/3A Horizontal Link Assembly Install Question Triumph 1
D TR2/3/3A Vent lid link length Triumph 8
J TR4/4A 67 IRS Damper arm/link removal help Triumph 10
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
S TR4/4A Reversing upper fulcrum link Triumph 3
B Parts for sale on Panjo link Austin Healey 0
M_Pied_Lourd TR2/3/3A Verticle Link to Trunnion Fitment Triumph 5
K Jaguar 140 Restoration Link? Jaguar 2
