Vertical Links
tinman58
I have the new bearings in hand, But took a second look at he axel stubs and some of the pitting and scoring, I thought I might as well replace the axel stubs too. To get the stubs off I had to pull the vertical link loose off the upper ball joint. Then I noticed that the vertical link is pretty tight in the trunnion. How thght or loose should it be ? The trunnions are new but the vertical links are orignal.After rebuilding the steering bow and installing urethane bushings the steering wheel still would not center it self. The right side trunnioun has much more friction then the drivers side. Any insight would be apperciated.
Dan
KVH
I'd make sure your stub axles are not scored, and get new ones if necessary.
When I reinstalled my vertical links, I had the same question you have about "how tight." Of course I was reassembling the front end and installing the trunions to the vertical links with no load, since the coil springs are removed at that point.
I called Harry at Moss Tech Support, now retired but someone I really liked and relied on, and he said you can tell instinctively.
He explained that when you put the trunion on, greased of course, it should not feel tight because it will then bind on a turn, and that if you put it on as far as possible with no binding on regular turns (meaning within the intended steering limits in both directions), with the trunion seal properly in place and not binding, it will be right.
I spent a few minutes studying each side, and he was right. The trunion will only go on so far, and still move freely without binding.
If one of yours is tight, I'd find out why and address the issue.
I'm not sure what you mean by the steering wheel not centering itself. If yours is like mine, then after putting the new bushings on, you may well have to loosen the upper bracket, pop the steering rod up and refit the rod into the splines. Not sure that's your issue, but whenever I'm messing with the bushings, the steering will be off and must be reset. Resetting isn't easy either. I always miss by a little, and I'm sure others know some easy way that eludes me.
Good luck.
TR3driver
Great Pumpkin - R.I.P
The vertical link should turn easily (like a bolt into a nut) until it hits the end of it's travel, or, if the grease zerk is in place and the trunnion has already been greased, starts to displace grease from the bottom of the trunnion.
The TR3 and early TR4 suspension has zero caster, so doesn't center as strongly as later cars. But it should still come back to center (when you are driving of course). If not, there is something binding or possibly something is bent. Herman reported finding a bunch of vertical links that were bent and would not turn easily with hard bushings plus new trunnions & ball joints, but mine were OK. Before I connected the steering, the links would literally flop to one side under the weight of the brake caliper.
The TR3 steering box has a center point, which you should be able to feel with the box properly adjusted. The steering wheel should be connected so it is centered at the same point. Then the tie rod ends get adjusted to make the car go straight with the wheel & box centered (and to set the toe-in, of course).
Moseso
The TR3 steering does not "self-center" out of a turn very well -- if at all. There is no (actually zero) caster angle in the system. You turn 'em in, and you turn 'em out.
The picture of your axle is not very pretty. It looks scored where the outer bearing should ride. I've followed your "bearings" thread -- and I haven't any insight into how/why it failed -- but if that axle feels as rough as it looks on the thin part, just inboard of the threads, I'd replace it too.
The vertical link shouldn't feel tight in the trunnion. Moving it from stop to stop shouldn't require two hands. But even if everything is all loosey-goosey and proper, your TR3 will still have to be steered out of turns, as well as into them.
I have heard that TR4 parts -- trunnions, upper A-arms and ball joints -- will bolt onto the rest of a TR3 suspension and improve this situation. They change the caster angle from 0 to 3 degrees, improving the self-center of the steering. I'm thinking about this mod -- for 2011 maybe.
TR3driver
I disagree. When it's right, it will return to center. The steering axis is tilted side-to-side (king pin inclination), which does create centering force.
tinman58
tinman58
Thanks for all yhe advice guys, I am going to replace all the parts (stub axels, bearings, vertical links, etc) I want the car to drive as fum as possible. I just sent the order in to Moss. Another $500 order but worth it.
Dan
S TR2/3/3A vertical links Triumph 8
svtmikey Front Vertical links Triumph 3
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
banjojambo Triumph tr3 vertical link wobble Triumph 2
V TR2/3/3A Vertical link check Triumph 2
S TR2/3/3A Vertical link Triumph 3
S TR2/3/3A How bad is this? Vertical link Triumph 12
J TR2/3/3A L/S Vertical Link Resistance Triumph 17
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
mcmillal TR4/4A Broken Vertical Link Triumph 17
J TR2/3/3A Need a TR3 vertical link Triumph 1
T TR2/3/3A TR3B vertical link Triumph 13
T Help on ball joint - vertical link fit Triumph 20
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
T Vertical link questions Triumph 4
Bremer Help with vertical link assessment Triumph 6
C Distributor shaft vertical play? Triumph 4
B Vertical link question Triumph 1
HEALEYJAG 100 vertical fin from apron panel set Austin Healey 8
M Removing Stub Axle from Vertical link Triumph 22
G trunion/vertical link seal Triumph 5
GB1 Vertical Oil Cooler Lines Racing 6
WALTER Vertical vs. Cross-flow radiator Spridgets 5
Dandare Healey Website Links Austin Healey 4
andrea 100-Six Photo Album Links Austin Healey 1
S Sway Bar End Links Austin Healey 15
S TR2/3/3A rear shock arms and links Triumph 4
A Spitfire BMCNE -Tech Session Custom Wiring Harness Creation -Links to Album Triumph 2
M BJ8 Damper links Austin Healey 2
A General Tech Here's Our BMCNE Newsletter - links to Collings Tour & Beatles Night Pics Triumph 1
S TR6 TR6 shock links Triumph 10
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
T TR2/3/3A How important are matching rear shock links? Triumph 9
S TR2/3/3A rear shock links Triumph 2
Randy Forbes Randy's Healey pictures links... Austin Healey 7
jlaird links Spridgets 1
D Gallery Links to Your Spridgets Spridgets 1
bugedd Removal of shock links Spridgets 11
tomshobby Links to video of our run on the Dragon. Triumph 4
D Rear Shock Absorber Links Austin Healey 7
M Radius Links Spridgets 5
JPSmit Links FORUM Navigation Questions 3
YankeeTR When you get done looking at these links... Triumph 1
jlaird Check these links Spridgets 1
69MGC Needed Sway Bar Links MG 4
bighly Trafficator Pictures and how-to links Austin Healey 2
D Wedge TR-7 rear suspension links Triumph 5
D LINKS Restoration & Tools 0
