Tube shock conversion kits???
Paul Johnson
When I did mine three years ago, the general consensus was that VB's were the best, so that's what I bought. It took 45 minutes, from opening the toolbox to washing my hands.
So far there have been no problems; about 10k miles.
G
The one-piece conversion for the TR6 that usually comes with a KYB shock is really made by British Parts Northwest, in Oregon or Washington I believe. I changed the shock to Spax because the KYB was a little harsh. The Spax is adjustable. All the vendors sell the one-piece now. The multi-piece kit is tougher to install and is supposedly stronger. Some have stated that the one-piece unit has been known to fail, ie crack. Others say that there will be an interference with tires. I have 205/70 and see no problems. I personally like the one-piece unit. I would like the welding to be a bit more substantial on it but it seems to be holding up well. The other option is to uprate the stock levers. This does improve the ability of them to "shock" and is a very good, and cheap, option of improving the rear suspension. I for one am interested in adding a sway bar to the rear but cannot do it with the Falcon twin mufflers. Any way of going "overhead" and where could I attach it to the swing arm with tube shocks in place. Revington makes a good looking coil-over rear suspension conversion but is a bit pricey for this application.
Bill
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T Tube shock conversion BJ8 Austin Healey 6
K TR4/4A 4A Tube shock conversion? Triumph 5
D DIY - Front tube shock conversion Spridgets 33
P BUGEYE REAR TUBE SHOCK CONVERSION Spridgets 0
M Question about Moss Tube Shock Conversion [pic] Triumph 9
bigbadbluetr6 TR6 TR-6 rear tube shock conversion question Triumph 20
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
theleisure Tube Shock Conversion Spridgets 8
C Tube shock conversion kit? Spridgets 14
angelfj1 TR5/TR250 TR250/6 - Tube Shock Conversion Triumph 5
regularman Tube shock conversion Spridgets 1
MadRiver Front tube shock conversion? Austin Healey 2
J tube shock conversion? Triumph 16
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
Wana Tube shock conversion? Austin Healey 9
jsneddon TR2/3/3A TR3 Tube Shock Conversion??? Triumph 2
M Tube shock conversion[rear]. MG 5
B TR2/3/3A 1958 TR3 rear tube shock conversion? Triumph 7
W Tube shock conversion? MG 1
A MGB MGB tube shock conversion. MG 17
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
Willie_P Urgent Help: TR 2/3/4 tube shock installation Triumph 3
L Front tube shock kits MG 13
Morris Front Tube Shock Kit Spridgets 16
Morris A new front tube shock kit Spridgets 5
6 Tube Shock Kit MG 1
S Rear Tube Shock Converstions Triumph 17
Shinsen774 Replacement Tube Shock Rear-Advice MG 1
Morris Front Tube Shock Mount pic Spridgets 14
RobSelina DIY rear tube shock ideas [finished w/ pics] Spridgets 18
R tube shock conversions Austin Healey 2
Andy Blackley Rear Tube Shock Conversions Triumph 26
A TR6 TR6 Rear Tube Shock Conversions Triumph 13
V TR6 TR6 Tube Shock Size [front and rear] Triumph 9
bobmga62 MGA rear tube shock replacement for MGA MG 0
C "Name that Tube Shock" MG 2
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
D Capillary Oil Tube Fastener Austin Healey 5
P MGB Tube axle wear MG 3
M Capillary Tube repair Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
