Urgent Help: TR 2/3/4 tube shock installation
Willie_P
guys (and gals):
A little stuck here and would like to get help today so I can get this done before the snow falls (non heated garage).
I installed the front tube shock and am confused on the mounting of the UPPER bump rubber bushings.
I have two thick steel washers and two poly bump stops to install per side.
DO BOTH of the poly bushings go UNDER the steel/frame turret or does one of the bushings go underneath the frame turret and one of the poly bushings go above the turret (ie: on the outside of the frame turret). (my disassembly notes are a little fuzzy and 5 yrs old!).
Thanks for the quick responses on this one.
willie
TR4nut
One above, one below - sandwich the turret area.. and stay warm!
sail
I agree, washer and rubber above and below. The bushings that came with my replacement shocks were not correct.
Willie_P
Willie_P
thanks guys. very helpful. got it done properly by 5pm Sunday. going to be in the 30's rest of the week (was 60 yesterday, Sunday).
wp
Woodie Urgent help...emergency flasher wiring Spridgets 7
hondo402000 TR6 Greasing the TR6 urgent help needed Triumph 2
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
dklawson Sorry... Urgent Request for Friend - Marina Front Engine Plate Other British Cars 2
dklawson MGB Sorry... Urgent Request for Friend - Marina Front Engine Plate MG 3
jlaird Urgent need Spridgets 6
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
bighly URGENT CALIFORNIA LEGISLATIVE UPDATE Spridgets 1
bighly URGENT CALIFORNIA LEGISLATIVE UPDATE Sunbeam (Rootes) 0
bighly URGENT CALIFORNIA LEGISLATIVE UPDATE British Motor Corp 0
bighly URGENT CALIFORNIA LEGISLATIVE UPDATE Triumph 0
bighly URGENT CALIFORNIA LEGISLATIVE UPDATE MG 0
bighly URGENT CALIFORNIA LEGISLATIVE UPDATE Lotus 0
bighly URGENT CALIFORNIA LEGISLATIVE UPDATE -fw Jaguar 0
bighly URGENT CALIFORNIA LEGISLATIVE UPDATE Austin Healey 0
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
