Transmission Tailshaft housing off center
Joe Schlosser
I was wondering if anyone has run into this before.
Last year I was doing final assy on my transmission rebuild and I had two tailshaft covers in the parts bin. One of them when bolted up to the main housing was off center where the tailshaft passed through making it impossible to insert the driveshaft.
I switched out the tailshaft housing for the other one in the box and it fit perfectly.
I just finished another rebuild that had been sitting around for a couple of years that needed a layshaft.
I had forgotten about the issues with the tail shaft cover but the same thing happened when I bolted it up, the tail shaft and the cover did not line up.
The tail shaft is straight.
I was wondering if any one has come across this issue and if there is a fix. I can shim the tailshaft but that raises issues with the seal against the transmission.
Any input is welcomed.
Gerard
Seems to me that the only thing that could cause this is some imperfection/raised surface on the mating surface that would cause the misalignment. Since switching housings made it go away, the flaw would have to be on the machined surface of the tail section. I would also check the alignment pin on bearing housing to be sure it's clocked exactly right and that the mating hole is unobstructed. Another possibility that comes to mind is the control lever not engaging the forks correctly.
Personally, I don't recall ever running into this problem.
Joe Schlosser
Joe Schlosser
Gerard
Thanks for the thoughts. It has me totally confused. I will have a look into the dowel pin hole. Totally weird. Trans came out good too (thanks for the clutch lever cover). Shifts very nice on the bench.
Joe Schlosser
Joe Schlosser
After trying everything I could think of I, filing, grinding, shimming, I could not get the tailshaft housing to align properly on thet shaft. A spare drive shaft piece never went into the housing smoothly.
I found a Tailshaft housing on Ebay and it arrived today. I just dropped it onto the main casing and the shaft and housing aligned perfectly.
I still have no idea as to what the issue was with the housing but it is destined for the scrap pile.
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
S MGB Transmission cross member re-install MG 14
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
WHT BJ8 Transmission Installation Austin Healey 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T How to ship transmission from Canada to Rivergate in Tennesee? Spridgets 8
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
A TR6 Installing differential and transmission Triumph 10
PAUL161 T-Series 5 Speed Transmission MG 85
PAUL161 T-Series Replacing Transmission MG 3
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
R TR2/3/3A Transmission Service TR-2 Triumph 58
Spock TR6 Transmission Plug Triumph 4
