CJD
I googled and taper pins are available from too many suppliers to list. This caught my eye, as they are super long tapers, so you can just insert until they lock and cut off the extra...so you don't have to know the exact size.
Ace even sells the reamers:
Again, these are available from literally a hundred different suppliers. The only hard part is finding the right size.
Better yet...Here is the TRF site. CT10 is the pin you are looking for, part number 513888.
Now, they do not have it in stock, but it turns out that you can take the part number over to Revington and they DO have it in stock.
Economy Insertion Tapers
Economy Insertion Tapers allow you to stretch your piercings easily and without pain. Who says that stretching and inserting new jewelry has to be difficult? These insertion tapers will make the whole process smooth, easy, and comfortable. These tapers are specially designed to be body-safe so...
www.thechaingang.com
General Steel T-Handle Reamer 1/8 - 1/2 in. 1 pc - Ace Hardware
The 130 T-handle reamer is ideal for removing burrs from cut pipe, tubing and conduit. It's also good for enlarging and counter-sinking holes in sheet metal, plastic and other materials.Find the REAMER1/8-1/2REPAIRMANS at Ace.
www.acehardware.com
MILLS PIN
www.revingtontr.com
